D16/D15B(OBDII) Injector Voltage
Old Mar 22, 2010 | 10:10 AM
Kigol's Avatar
Default D16/D15B(OBDII) Injector Voltage
What is the proper voltage reading I should be getting across the injector wire harness pins when the car is cranking? I get a 12.5 voltage drop to ground so I know they have power. Just want to know how much is needed to pulse the injectors when the circut closes. Thanks.
Old Mar 23, 2010 | 06:25 AM
Kigol's Avatar
Default Re: D16/D15B(OBDII) Injector Voltage
Please if someone has a second can they remove a plug from thier injector and just test the voltage between the two pins on the wire harness while the car is cranking/running? I really need to know this information to diagnose whether or not I have wiring issue...I would really appreciate it. Thanks.
bump.....
Old Mar 23, 2010 | 01:33 PM
Kigol's Avatar
evening bump
Old Mar 23, 2010 | 07:47 PM
JUSTTURBO's Avatar
well idk if mine is right because i just swaped my sc over to a d15b and i cant get my motor to run it will crank but not run?.... but my injectors run around 12.... when am trying to crank it but while runing idk cuz i cant seem to get it to run? hope it helps some
Arthas
Mar 3, 2010 05:08 PM
rick_rabies
Jun 16, 2009 06:02 PM
Jayman_Gsr
Nov 21, 2008 05:18 AM
Hondatec38
Mar 4, 2003 08:57 PM
Sleepin'
Jan 31, 2003 02:03 PM
