XTD clutcn on sohc
Old Mar 21, 2010 | 09:07 PM
G3O's Avatar
G3O
Default XTD clutcn on sohc
Has anyone tried a xtd con a sohc vtec motor non turbo,my clutch is goin out. It is a 16 year old clutch , I wanna get XTD clutch stage 3 since I hear good reviews about them,but most of the cars are turbo,I wanna get good accel response is 7.5 lb flywheel good ? Will it be hard to drive,I drive my sohc hard that's y I want a a strong clutch but not expensive like act since I plan on swapping or turbo'ing later in fall
Old Mar 21, 2010 | 09:35 PM
Linked's Avatar
Default Re: XTD clutcn on sohc
i have the exact setup as you want (xtd stg 3 with a fidanza 7.5lb fw)
since i;ve never drove a manual, and put those on the second i swapped from auto, i cant tell you the difference vs oem clutch and fw
but i DD my setup miles a day and the driveability is very easy once you get used to a more sensitive clutch.
i suspect my MPG has went down though since i have a lighter flywheel
btw accel is awesome, i have a stock z6 and its like i unlocked the other half of my engine with a manual and the clutch and flywheel
Old Mar 21, 2010 | 10:00 PM
G3O's Avatar
G3O
do u mean ur mpg went down in a good way or bad way ur wasting less gas??
Old Mar 21, 2010 | 10:16 PM
Linked's Avatar
my mpg was less than what some people here say they get with sohc vtecs.
no CEL and replaced my o2 sensor, air/fuel filters, and spark plugs, i havent checked fuel pressure yet but i've come to believe my engine burns more gas because the lighter flywheel doesnt give as much rotational energy as a heavier one would (i would think that aids the engine)
Old Mar 21, 2010 | 11:08 PM
nothing_shocking's Avatar
I'm pretty sure light flywheels improve mpg because it takes less to turn the motor... I think I saw that discussion on here not too long ago.
Old Mar 22, 2010 | 11:39 PM
G3O's Avatar
G3O
well mu sohc kills alot of gas regardless lol my cel is on i have something wrong with the vtec selenoid it says i think wiring or so and my wiring for my 02 sensor
Old Mar 22, 2010 | 11:55 PM
Single Sixteen's Avatar
I have the xtd stage 4 on my y8 going on about 8000 miles and have had no problems i would get one agian.
Old Mar 22, 2010 | 11:59 PM
G3O's Avatar
G3O
cool thnx so far to revies on non turbo sohcs i think ill get one,but how is the drive ability on them are they easy to daily drive,is it like driving a sports car
Old Mar 23, 2010 | 12:40 AM
It all depends on how you like to drive i drive rough so the stage 4 is perfect for me but i like it either all power or no power there isnt much room for play.
xotic_crx
May 25, 2013 02:59 PM
jdmsir4dr
10
Apr 12, 2009 05:07 PM
ektrip303
13
Aug 3, 2006 12:16 AM
Honda-Hooligan
Mar 10, 2005 07:51 PM
ieatrice
Jul 29, 2004 07:26 AM
