Which FPR?
Old Mar 21, 2010 | 08:44 PM
JacksonD's Avatar
Default Which FPR?
So I installed my bigger fuel pump and realized my fp is through the roof, there are two brands fpr I am looking at, the B&M for 54.00, or the AEM 179.00 . Im not sure which to go, id like the b&m because of price, but i also want to put in a gauge and im not sure if it has a port or not, i know I could probably do an inline gauge, but quality wise which would be better?
Old Mar 22, 2010 | 06:21 AM
JacksonD's Avatar
Default Re: Which FPR?
bump
Old Mar 22, 2010 | 06:50 AM
dephtone's Avatar
Your fuel pressure regulator should be fine with the stock one in. I run a walbro with stock injectors and FPR and it works just fine.
You may want to look into maybe swapping out with a different one.
If you are set on buying one, I would recommend the AEM one as the B&M one you have to hack up your existing FPR.
Old Mar 22, 2010 | 07:44 AM
redef90si's Avatar
x2 I also has a walbro fuel pump and stock fuel injectors/fpr I'd do a little more research and see if you reall need the upgraded fpr?Just my opinion,Matt
Old Mar 22, 2010 | 08:16 AM
JacksonD's Avatar
I thought the same, but like four people told me it was the fpr. https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/crx-everyday-struggle-2745134/
Old Mar 22, 2010 | 08:53 AM
JacksonD's Avatar
I found a good price on a blox for but don't know too much about the brand any info? It's a whole unit not reuse stock fpr
Old Mar 26, 2010 | 07:13 PM
91CR-XSiR's Avatar
if u wanna upgrade ur fuel pressure u should get the bdl FPR, rail, and filter. a walbro fuel pump will do nothing but get u back to stock fuel pressure, thats what a FPR is for (to regulate higher pressure of fuel to the rail)......lemme know if u wanna see it done the right way i drop sum pic for ideas. goodluck man
ATS*Mark
Jul 20, 2004 06:16 AM
85mm LS VTEC
Mar 25, 2004 10:52 AM
Mark
Sep 15, 2003 11:00 AM
dochmees
Nov 21, 2002 12:16 PM
