Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
IT racers with sheet metal sunroof
Old Sep 8, 2002 | 11:46 PM
jasonb's Avatar
Default IT racers with sheet metal sunroof
For those IT drivers who for one reason or another have replaced their OE sunroof with a piece of sheetmetal, what metal and guage of metal did you use? Unfortunately, my stock sunroof skin is bent out of shape, so I'd like to replace it with a sheetmetal panel. I know that the GCR states you can replace the sunroof with a panel or replacement skin of the same material, but it says nothing about the guage of the metal.
Old Sep 9, 2002 | 05:31 AM
Crack Monkey's Avatar
Default Re: IT racers with sheet metal sunroof (jasonb)
It should be the same thickness as the remainded or the roof.
Old Sep 9, 2002 | 06:21 AM
Ausmith's Avatar
Your best best is to find a junker that does not have the sunroof and cut the complete roof off and use it your material. It is going to be the proper thickness and will have the proper contour.
Old Sep 9, 2002 | 06:23 AM
WuWarrior's Avatar
my sunroof was removed and replaced with sheet metal before I bought the car. The metal looks to be just as thick or a little thicker than the rest of the roof. It is riveted down. should be easy
Old Sep 9, 2002 | 08:48 AM
Steve91's Avatar
Default Re: IT racers with sheet metal sunroof (WuWarrior)
WuWarrior,
Could you post some pictures of this?
Thanks
Old Sep 9, 2002 | 08:52 AM
WuWarrior's Avatar
Default Re: IT racers with sheet metal sunroof (Steve91)
All of the pics of my car are here: http://evillinux.mine.nu/~ed/warrior/
there should be some that show the roof. if not, let me know and i will take some pics myself.
Old Sep 9, 2002 | 08:07 PM
travis's Avatar
The money shot is here:
http://evillinux.mine.nu/~ed/warrior...ord%20Roof.jpg
It looks really good! I hope mine turns out that nice. Is it water proof? Any other pics? This is the only one I found.
Old Sep 9, 2002 | 08:11 PM
WuWarrior's Avatar
Default Re: IT racers with sheet metal sunroof (ITR#231)
when there is snow on top of the car some water will leak through the antenna. otherwise, it is just fine.
[Modified by WuWarrior, 5:12 AM 9/10/2002]
Old Sep 10, 2002 | 09:50 AM
Phoenix_ITR's Avatar
OT -- but i thought that HART was Honda of America Race Team... am i mistaken?
Old May 13, 2003 | 03:57 AM
keithv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jasonb &raquo;</TD></TR><TR><TD CLASS="quote">what metal and guage of metal did you use?</TD></TR></TABLE>
since this question was never answered in this post, i will ask. i am going to use a replacement panel and am not looking to reskin the roof. does anyone know what gauge sheetmetal i should buy???
thanks.
Old May 13, 2003 | 05:22 AM
uncleben's Avatar
Default Re: IT racers with sheet metal sunroof (keithv)
I'm fairly certain the gauge we used was thicker than the roof - it feels more solid too. Anyone think this will cause me a problem when i get my car teched at my first SCCA school/regional this weekend?
https://honda-tech.com/zerothread?id=457186
Old May 13, 2003 | 06:16 AM
Doctor CorteZ's Avatar
how bout some bling ?
Old May 13, 2003 | 06:18 AM
Tyson's Avatar
Default Re: IT racers with sheet metal sunroof (uncleben)
uncleben, thats exactly the way i wanted/will to do it. thanks for sharing pics. not sure how i missed the first post. glad to see it comes out well.
btw, CF isnt legal.... not that you were serious.
Old May 13, 2003 | 07:01 AM
Default Re: IT racers with sheet metal sunroof (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">btw, CF isnt legal.... not that you were serious.</TD></TR></TABLE>
hopefully it is in ECHC , I'm serious about that...
Old May 13, 2003 | 10:28 AM
rex_boy's Avatar
Has anyone left the OE metal sunroof in and secured it. I believe they make some kind of clips for this but can't seem to find any info on them.
Thanks in advance.
Old May 13, 2003 | 12:52 PM
Default Re: IT racers with sheet metal sunroof (rex_boy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rex_boy &raquo;</TD></TR><TR><TD CLASS="quote">Has anyone left the OE metal sunroof in and secured it. </TD></TR></TABLE>
make two straps , bolt into roof , bolt to the sunroof panel.
done.
Old May 13, 2003 | 01:03 PM
Want2race's Avatar
Default Re: IT racers with sheet metal sunroof (Doctor CorteZ)
the way i did mine
http://want2race.net/racecar/howto/roof.htm
its waterproof when u add a strip of helicopter tape over the top..
Old May 13, 2003 | 02:49 PM
Knestis's Avatar
Default Re: IT racers with sheet metal sunroof (Want2race)
SCCA rules silliness #451:
It is not legal in Club Racing to tape over body seams on stock-bodied cars...
Kirk
Old May 14, 2003 | 06:12 AM
gsirnj's Avatar
On my car, I used 26 guage galvanized sheet metal from Home Depot. ~$20 for a 3'x2' piece. This thickness was workable (bendable and cut-able). Personally, I think it is a bit thin, but it passed tech last week. Because this is a bit thin, everytime I hit a bump/curb on the track, I have a steel drum going off above my head. I recommend putting in support rods (to stiffen) and gluing some foam (to kill the drumb effect) on it. (Sorry no pictures until I can buy a digi camera.)
I finally found a local metal worker/welder and he had 20 guage dark metal. The "dark metal" actual steel sheet, as opposed to aluminum (duct type) sheets. Cost about the same. I will install that sometime.
Old May 15, 2003 | 07:24 AM
keithv's Avatar
Default Re: IT racers with sheet metal sunroof (gsirnj)
what if i were to use say 20 gauge material. its thicker than what the rest of the roof is, but it will weigh more. i figure the way the rule is worded is for people to not go thinner than what the rest of the roof is?
Old May 15, 2003 | 07:40 AM
bdb's Avatar
bdb
22 gauge will work.
Old May 16, 2003 | 02:35 AM
jc836's Avatar
The alternate to finding and salvaging is to buy the genuine Honda 2nd gen DX roof skin panel. We gutted the roof (and interior as well) and the new panel was welded in. The ITCS permits this as an alternate to welding a sheet of steel (correct gauge) over the opening or using straps, etc. BTW: The skin panel sells new for ~$300 retail and $250 with discounts.
Old May 17, 2003 | 04:21 AM
10K2HVN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsirnj &raquo;</TD></TR><TR><TD CLASS="quote">Personally, I think it is a bit thin, but it passed tech last week. Because this is a bit thin, everytime I hit a bump/curb on the track, I have a steel drum going off above my head.</TD></TR></TABLE>
hehe..lol!! =D
Old May 17, 2003 | 09:36 AM
uncleben's Avatar
asked my pop what we used and he said 22... could have gone a little thinner, it was semi-difficult to manipulate at this thickness
apexassassin
Jul 28, 2010 09:25 AM
ProJectRawDA9
Paint and Body
Oct 19, 2009 08:35 AM
miramesa
Dec 8, 2006 06:16 PM
hmtcrxsir
14
Mar 31, 2006 01:50 PM
RC211V
Audio / Security / Video
Sep 9, 2002 01:44 PM
