neutral safty switch problem
hey i got a 91 civic hatch dx and it wont start the neutral safty switch isnt working when your push the pedal it will work when i go under the dash and push it but when u push pedal its not hitting the switch , dose anyone have any advice on how to adjust the pedal or switch or rig somthing up or bypass the switch completely any info would be appreciated
The plastic piece that makes contact with the switch may have come apart, look for a "blue crayon" looking part on your floor board. It's the same Honda part that is used on the brake light switch that always goes bad, there are a lot of write-ups for the brake lights staying on and how to fix that but not many on the neutral safety switch, but i have had to change both of mine in the last couple of years and I used the same Honda part for both. It's a little plastic plug that just pushes into a hole on the clutch pedal arm or the brake pedal arm depending on which one you're fixing.
ya thats probably the problem same thing happened on my old sedan but it was the switch for the cruise control on the clutch. but if you wana rig it just take the plug off the switch and jump the 2 wires and then you wont have a saftey switch anymore.
i need to know the location of the neutral safty switch on my crx 91 automatic? lep me out bro its stuck on parking,i know it makes this click noise once u push down the brake to release the shift out of parking but it dosent make that noise at all???? i just dont know were its location at ? some say its by the tranny and some say under the dash ? so plz help me out im stuck here in LA
bro I just got down by the dash under the brake pedal and seen a switch but dosent look like the picture of a neutral safety switch? but I'm looking for a way to release the shift out of parking. like I push in the brake it dosent release it at all plus i push in the brake pad and the seat belts come on even when I push in the horn it comes on with the seat belt?????help me out is it fuse? or bad switch. its a crx91 automatic 1.5 hf
On the back (top right corner)of the under dash fuse panel there are 2 thick (10gauge) black with a white stripe wires If you connect them together it bypasses the whole interlock system.
crazyjetsfan22
Jul 20, 2011 03:34 PM
91efbluehatch
Jan 30, 2011 12:56 PM
irondragon013
Jun 28, 2008 02:03 PM
