Suspension & Brakes Theory, alignment, spring rates....
Camber Kit
Old Mar 21, 2010 | 02:04 PM
asphalt788's Avatar
Default Camber Kit
Im going to start this off by saying I don't care about your opinion on if I need a camber kit or not. Im going to get one no matter what. I was wondering if anyone has tried those cheap camber kits off ebay. The ones that look like square blocks with a bolt through the center.
Old Mar 21, 2010 | 02:13 PM
lobudgetr's Avatar
Default Re: Camber Kit
I have used them, they work. The only negative I see to them is lack of adjustability.
Old Mar 21, 2010 | 02:33 PM
kristo's Avatar
Loved
Originally Posted by asphalt788
1. Im going to start this off by saying I don't care about your opinion on if I need a camber kit or not.
2. Im going to get one no matter what.
3. I was wondering if anyone has tried those cheap camber kits off ebay.
There really is logic to madness.
Old Mar 21, 2010 | 02:39 PM
98civdx's Avatar
Master Detailer
freind had a cheap ebay kit, it broke within 6 months and he crashed causeing thousnads in damage to his car. DO NOT BUY EBAY!!
buddy club,skunk2 and they are others that make camber kits that are great.
Old Mar 21, 2010 | 05:05 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
<-- doesn't understand why people want to waste money on crap parts when their car would be safer, handle better, and alignments would be much easier and cost less if you just stick with OEM parts.
Old Mar 21, 2010 | 06:04 PM
asphalt788's Avatar
The reason why I am even thinking about using them is I am planning on lowering my car and I would like to get my alignment back to factory settings.
Old Mar 21, 2010 | 06:32 PM
98civdx's Avatar
Master Detailer
^ then use good parts the first time, and dont put yourself or any others in danger because you decided to use shitty parts.
i have been lowerd 3-3.5 inchecs for almost a year, and am just now showing signs of camber, a little bit of negative camber will not hurt. you really need to worry about toe.
Old Mar 21, 2010 | 07:19 PM
96hb's Avatar
LOL! Just buy whatever the hell you are looking at because we already know you have your mind made up. Buy a cheap *** kit on Ebay, install it, regret it in a few months, and either upgrade it or take it off altogether. Be sure to let us know how that works out.
Old Mar 21, 2010 | 07:31 PM
Community Builder
Toe is the critical angle to adjust to factory settings to save your tires from being trashed, and that's already adjustable stock. Negative camber by itself really doesn't cause much tire wear at all.
Old Mar 21, 2010 | 08:20 PM
1.5Slowmatic's Avatar
my skunk2 pro series plus is pretty easy to adjust. the guy who did my alignment even commented on it being easy as hell to do. I have the rears as well but damn do they squeak due to the fact that you cant lube them. I have been considering buying poly lube and taking the front bushings apart and lubing them because i bought them used and the squeak but not as bad as the rears. I have yet to have any "hitting" of the shock tower due to me not being slammed. The fact that i picked them up for 100 bucks for the pair seems decent to me. Especially since my stock arms had shot bushings and ball joints. I say, if your going to upgrade, don't cheap out. I also repacked the ball joints on the skunk arms with bearing grease just in case. My only complaints with the fronts are the squeak which i can fix. But the rears are coming out and getting replaced with something else.
Old Mar 22, 2010 | 05:37 PM
EJ1civic coupe's Avatar
wouldnt recomend it..i had a set for the rear just for temporary n the bushings were shot within a month lol..as well as a set of ingalls for the front..messed up with buying those to..bushing got messed up in those as well..if ya have to just get em for a temporary fix and just save up for sumthin else..gl
Old Mar 22, 2010 | 06:11 PM
.Manny.'s Avatar
Touching My Member
Just get the ebay ones. you're gonna buy useless parts anyway, why not buy inferior ones?
Old Mar 22, 2010 | 06:18 PM
bsmith100's Avatar
You don't have to worry too much about the extra camber in terms of tire wear.
If anything, I think the extra negative camber on the front wheels actually helps turn in at higher speeds.
Old Mar 22, 2010 | 08:35 PM
alphalanos's Avatar
keep oem upper arms. lower the car. get alignment with toe set to zero. and drop the "im doing it cuz i want to but have no idea why" mentality. we are trying to help you and save you money.
Old Mar 22, 2010 | 08:46 PM
Apprentice-X-'s Avatar
I bought the Skunk2 Tuner Series a while back for my EK and holy **** do I hate them, it's too damn stiff! (Makes the ride bumpy as heck). Unfortunately my bro cleaned up his garage and tosses my OEM upper arms away, game over. =(
So I'll probably upgrade to Skunk2 Pro Series Plus later on and pray the bushings allow for a better range of motion otherwise it'll look like I'm head bop'n the whole way.
Old Mar 22, 2010 | 09:15 PM
BiG ChOr!Zo's Avatar
Trail User nuff said
Old Mar 23, 2010 | 12:00 AM
bsmith100's Avatar
I don't think the ride will be any better. Why not order a new set of OEM arms?
Old Mar 23, 2010 | 12:19 AM
kevinm1981's Avatar
buddy club or skunk2 have good clearance
Old Mar 23, 2010 | 04:29 AM
non-VTEC's Avatar
buy the cheapest stuff you can so you can spend double in the near future to replace those shitty parts.
Old Mar 23, 2010 | 04:57 AM
Community Builder
But not as much as OEM.
Old Mar 23, 2010 | 11:35 AM
or just dont ride dumped like an idiot and you dont need to worry about clearance with them. Im dropped 2.5in and i have yet to have any contact what so ever with my skunks.
Old Mar 31, 2010 | 11:28 AM
You're probably right, I might do just that.
400whp
Mar 26, 2016 12:52 PM
91EF919
Mar 25, 2009 11:11 AM
4drteg916
Feb 21, 2007 04:33 PM
turbo_b16_ex
Oct 12, 2005 01:59 PM
