Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Locked out, battery dead, tried everything.
Old Mar 21, 2010 | 01:14 PM
DumpdEJ6's Avatar
I like the tuna here
Default Locked out, battery dead, tried everything.
Whats up guys! My friend has a Honda CRV with power locks. The battery died, then he managed to lock his keys inside somehow. We can't manually unlock the doors using the coat hanger trick, I managed to snag his keys that were in the ignition with two coat hangers wired together and the key fob broke. Tried popping the hood with a coat hanger hook to get it power so I can unlock the doors, but I can't see the lever or get my fingers under the hood to get it that way.
The only thing I can think of to try is to somehow get power to the car, then reach in with the coat hanger and unlock it. But there it sits, impenetrable, mocking me. I've been trying to unlock this motherfokker for 4 hours now, and NOTHING I can think of is working.
Does anyone have any ideas?
Old Mar 21, 2010 | 01:42 PM
lotz6996's Avatar
Default Re: Locked out, battery dead, tried everything.
if its a first gen you should be able to get to the power wire on the alt. from under the car. that wire will feed power to the battery and the rest of the car. if its a newer one you can always crawl under it and check. you can ground it anywhere under the car.
Old Mar 21, 2010 | 01:52 PM
DumpdEJ6's Avatar
Yeah its older. So I can run a wire from a new battery to the alternator power wire, run a ground to the chassis, and that should give me power? I'll try that, then report back.
Old Mar 21, 2010 | 04:47 PM
DumpdEJ6's Avatar
I only had like some 24ga speaker wire so I couldn't hold it on there very long or it would burn up, but I got the coat hanger into position holding the unlock button in the up position and connected it. It got power, but didn't unlock it.
So when my buddy got back we left the unlock button in the neutral position and I connected it and he quickly pulled it up.
WORKED LIKE A CHARM! THANK YOU!! :-)
Old Mar 21, 2010 | 04:49 PM
lotz6996's Avatar
great. glad it worked for you.
Old Mar 23, 2010 | 10:42 AM
Kaijhin012's Avatar
wow, good info. thanks.
Old Mar 25, 2010 | 08:20 PM
kitkat127's Avatar
wow... great info! thanks!!
ryanangelo212
Apr 27, 2013 07:43 PM
JackSparrow
Honda Civic (2006 - 2015)
May 9, 2010 06:39 PM
DumpdEJ6
Mar 21, 2010 01:44 PM
roller3804
Jan 21, 2008 09:48 AM
notguilty411
Audio / Security / Video
Nov 8, 2005 08:43 PM
