DIFFERENCE between 0BD1 F22 AND OBD2 F22
Is there any thing different on the F22 engines. Like as mounts? Intake manifolds? I know the connectors maybe be different. reason I ask is because I might have to do an engine swap for some one on a 1993 accord. and I found a 1997 accord parts car.
Well you're not comparing an F22BX to an F22BX, you're comparing different F (F22A to F22B) series. So there's quite a bit more difference between these.
Well on non vtec the heads are different and obd2 has a couple more sensors that wont need to be connected. With the vtec motors every thing is the same but of course obd2 will always have more sensors. They both have the same connectors tho i had to do this type of swap in one of my accords.
