Do aftermarket plug wires make a difference??
Old Sep 8, 2002 | 10:47 PM
SC0TT's Avatar
Default Do aftermarket plug wires make a difference??
Thinking about getting some magnecor wires for my b16. Is there much of a difference using them? Cause theyre might be better thing to buy for $90. Thnks
Old Sep 8, 2002 | 11:41 PM
SIRX's Avatar
Default Re: Do aftermarket plug wires make a difference?? (cr-tegra)
on a stock motor? NO.
Old Sep 9, 2002 | 04:14 AM
tommycrx's Avatar
I've got 'em. Yes, they do make a difference. They're thick and red!
I needed a new set, and they're fairly inexpensive. They certainly won't hurt. Check out their website - they have a good deal of useful info on there. But like the other person said, unless you have tons o' mods, ie, msd igntion, etc., there won't be a butt dyno difference.
Old Sep 9, 2002 | 09:29 PM
EF_LSVtec's Avatar
Default Re: Do aftermarket plug wires make a difference?? (tommycrx)
I had magnecor wires and made my idle fluctuate when I had my car smogged by state ref...He advised me to put the stock back in...worked fine after that. Didnt notice any power loss or anything. Stock one works. If it aint broke...yata, yata yata...
Old Sep 9, 2002 | 09:31 PM
MrTodd's Avatar
Default Re: Do aftermarket plug wires make a difference?? (EF_LSVtec)
Yeah, definitely no power increase as mentioned above. But it might help in emissions a bit, and maybe a smoother idle. But I've never used these before, so I really couldn't tell you from experience....
Old Sep 9, 2002 | 09:35 PM
dustin's Avatar
Default Re: Do aftermarket plug wires make a difference?? (MrTodd)
Don't get them. My car has died on the road several times with them because they POP OFF the distributor and the spark plugs.
Both of my cars now use brand new OEM spark plug wire sets -- they own.
Dustin
Old Sep 9, 2002 | 10:04 PM
island_son's Avatar
Default Re: Do aftermarket plug wires make a difference?? (dustin)
Hey Dustin let me guess:Magnecor wires right?
Same thing happens to me, I can't stand them.
I run NGK wires now and I love them.Fit exactly
like OEM.
Old Sep 9, 2002 | 10:23 PM
dustin's Avatar
Default Re: Do aftermarket plug wires make a difference?? (island_son)
OEM wires are made by NGK.
Magnecor wires
Old Sep 9, 2002 | 10:52 PM
Lamchop0000's Avatar
that black erick's civic coupe with the hondata has stock wires. and revs to 10,300rpm or somewhere up there
Old Sep 9, 2002 | 11:15 PM
RexB16's Avatar
Default Re: Do aftermarket plug wires make a difference?? (lamchop0000)
aftermarket plug wires = joke.
Old Sep 10, 2002 | 12:57 AM
ExospeedAMcrx's Avatar
Default Re: Do aftermarket plug wires make a difference?? (RexB16)
yup, stay with the NGK wires, everyting else is junk.
Old Sep 10, 2002 | 06:24 AM
EF8_SiR's Avatar
Default Re: Do aftermarket plug wires make a difference?? (exospeedAMcrx)
NGK
Had Magnecors b4 - stupid universal design doesn't "cap" on. Then went to Viteks -and damn, almost worse wires made ever. Breaks apart on you. Now running NGK - nice OEM fit
Old Sep 10, 2002 | 06:40 AM
ricodemus's Avatar
Default Re: Do aftermarket plug wires make a difference?? (EF8_SiR)
yup, ngk for me after I shelled out 70 on the MSD wires and they fit like Dustin described.
Old Sep 10, 2002 | 09:57 AM
ijjz's Avatar
Default Re: Do aftermarket plug wires make a difference?? (ricodemus)
Reason why they pop of is because of your old gasket seals, replace them when you get your new plugs and everything will be fine. That is how I fixed my problem with the MSD wires.
Old Sep 10, 2002 | 10:03 AM
Urban Business
Guest
Posts: n/a
Default Re: Do aftermarket plug wires make a difference?? (ijjz)
plugs and wires are kind of a useless upgrade. plugs, your preferance. wires oem or equivilant. think wires have dick to do w/ spark its the same sized core w/ more insuation. however i do like how msd wires are wound. quite conductive.
ignition **** helps, you definatly feel the difference (least i did, however i notice the cars performance fluctuating with every 2* outside air temp :shrug
i have acell wire on now, hyper spark or some crap ****. 7.5mm i believe, they're useless. always poping off the dizzy
Old Sep 10, 2002 | 11:17 AM
4gvtec's Avatar
i like my nologys, have not had any problems.
Old Sep 10, 2002 | 11:29 AM
.nate's Avatar
Default Re: Do aftermarket plug wires make a difference?? (4gvtec)
Magnecoires blow.. they pop out of the motor. Just get NGK wires.
Old Sep 10, 2002 | 01:32 PM
Urban Business
Guest
Posts: n/a
Default Re: Do aftermarket plug wires make a difference?? (N8-T)
i love the avitar, if it wasnt for napa, advance autoparts (shitbox autos b/c of the **** parts) and all the hardware stores i wouldnt have a car
staticCRX
20
Mar 13, 2006 02:47 PM
LudeAchris2001
Jan 5, 2005 03:18 PM
FalconMan
Dec 15, 2003 01:53 PM
4gvtec
May 13, 2002 08:44 PM
