HELP!!!! Can't find door triggers!!!
Old Mar 21, 2010 | 04:53 AM
GsDAteg's Avatar
Default HELP!!!! Can't find door triggers!!!
So I'm finishing up this alarm install and I can't find the door triggers in a 90' Integra GS. I'm following suspendedhatch's site for most my install but where it says to connect to the door triggers it is not working. The site says the door trigger should show continuity to ground with doors open and infinite resistance with doors shut. But yet no matter which wire I try it always shows continuity to ground with doors both open and shut.
So what am I doing wrong? No matter which wire I try it's the same thing. I tried the only green/red wire running under the driver side back seat where his site shows you to access it and it shows continuity to ground with doors open and closed. So I tried a few other green/red wires in the bundles under the driver sides door sill and same thing.
HELP!!
Old Mar 21, 2010 | 11:14 AM
Jdmglenn's Avatar
Default Re: HELP!!!! Can't find door triggers!!!
are you doing it on the thick one or the thin one
Old Mar 21, 2010 | 06:14 PM
audioroach's Avatar
okay a few things.
- is your meter set to dc voltage? (hopefully you are using a digital one)
- take your black probe and connect it to a good ground. probe the wires with the red
one. the meter should show a positive voltage when the door is closed and go to a ground (no voltage) when open if you have the correct wire.
- is the interior light coming on when the door is open? if not check for corroded or poor
contacts at the door switches
karrar55
Honda Civic (2001 - 2005)
Feb 18, 2014 01:06 AM
laziebun
Audio / Security / Video
Oct 7, 2009 03:53 AM
steveharrmr23
Nov 19, 2008 01:41 PM
Odessa
19
Aug 3, 2004 06:37 PM
