Need some help figuring out my wideband sensor.
Old Mar 20, 2010 | 09:59 PM
Supa Troopa's Avatar
Icon2 Need some help figuring out my wideband sensor.
So I got this wide-band sensor 3 years ago and its brand new. I am about to get an AEM gauge for it and I figure since I have this sensor, I figure I don't have to pay the extra for another one. My problem is that the wires are different colors. I have been searching Honda-Tech for 3 days and have not successfully found anything. Does anyone have experience with this sensor so I can use it for the gauge? I just need to know which wires do what. Thanks for your assistance.
NGK NTK 5-Wire Wide-band sensor
Wire colors:
*Yellow
*Blue
*White
*Black
*Grey
The only thing I have found is this:
http://www.summitracing.com/parts/NGK-24302/ This is the actual unit itself.
Old Mar 23, 2010 | 05:31 PM
Default Re: Need some help figuring out my wideband sensor.
Did I post this in the wrong section? If so can someone re-direct it?
I am just wondering if anyone knows what these wires are for, like a diagram.
Thanks
Old Mar 23, 2010 | 07:35 PM
Jaker's Avatar
That sensor will not work with any of the current Wideband kits out there. You need the driver circuitry for the wideband as well as the gauge. The sensor will not run on it's own to feed a gauge.
The current crop of Wideband kits are all designed to run off the Bosch sensor, not the NTK sensor like Honda used.
If you could find yourself a PLX M200 or M250 kit (you'll only find it used as it has been discontinued by PLX), then you'll be able to use your sensor. It would probably be cheaper to go out and buy a whole PLX, Innovate or AEM wideband kit. Sell you Honda sensor on eBay. You'll probably get a good chunk of the cost of a complete new wideband kit from the sale.
Vtec04
Sep 21, 2017 04:00 PM
cd5ryan
Jun 29, 2010 07:30 PM
chrisfromsrq
Jul 29, 2009 06:29 PM
_Endless_
Oct 31, 2002 09:07 AM
Brian_92GSR
Aug 9, 2002 09:34 AM
