JDM DC2 hub bearing and ball joint, I have question??
Old Mar 20, 2010 | 08:45 PM
k20tuned's Avatar
Default JDM DC2 hub bearing and ball joint, I have question??
Can anyone tell me the part numbers for JDM DC2 front hub bearing (spindle) and ball joint.
Is the bearing the same since JDM is 36mm and USDM is 32mm?
Also can these parts be purchased at Honda here in USA?
Old Mar 20, 2010 | 10:49 PM
jdmtodadc2's Avatar
Default Re: JDM DC2 hub bearing and ball joint, I have question??
I replaced my bad JDM ITR ball joints with US ITR ball joints. There was no visual differance between the two. As far as the hub bearing well I'm not sure on that.
Old Mar 20, 2010 | 11:01 PM
nastyARE's Avatar
order front wheel bearings for like a 2001 honda crv, and the ball joints are the same, might as well go with some aftermarket extended ball joints if your lowered
CTRfan00
Mar 19, 2014 06:07 AM
Creator
Apr 14, 2011 06:03 AM
kamciu80
Sep 3, 2010 10:42 PM
Bnjmn
Sep 20, 2005 03:43 PM
ckkl
Apr 23, 2002 07:49 AM
