what do i need to swap B18C5 on a del sol?
i know this get asked alot but i cant seem to find a place were it tells me what i realy need to do this swap. i have a 93 Del Sol d16z6. what do i need to do this swap. So far i know i need engine (obviously), tranny, wire harnes, mounts and ecu from the c5. But what shift, and axel do i use? and what else will i be in need?
you need to grab a shift linkage from a del sol vtec they are hard to find so you will prolly have to go to honda and see about getting it and just grab some axles from a del sol vtec ,teg nothing major
its just out with the old in with the new... theres nothing that i should know befor? fabrication that maybee will need to be done or something?
nopes. it might fit a lil weird but beyond that it'll be easy. i went from a d15 to b16 and its simple. i needed a new upper i think it was radiator hose.
there is no need to fabricate anything. and u asked about axles: u can use ANY B-series Civic/Del Sol/Integra axles.
also different A/C compressor bracket and Power Steering pump bracket if you are going to reuse them.
if the tranny is a cable tranny u can either sell that tranny and pick up a b series hydro(which is wat i would do), or u can get a cable to hydro converson kit for your car...
get a conversion kit on ebay and tran depends on how short u want ur gears ls is the longest geared trans b16 is the shortest all b seris trans will change u may have to cutomize ur shift linkage and 95-00 teg axles del sol axles will not work they didnt make a b seris delsol i dont think but if u can find a b seris hydro trans id get it
there are a number of companies who make the conversion kit, but id go with a hydro tranny, and they did make a del sol with a b16, u will need to get shift linkage from that model(si model i believe) to fit.
thanks for the help!!!!!!!!!!
....... will be going soon to de dominican republic to get my b18c5 because here in PR: 1) im not going to find one and if i do there are going to ask for to much. 2) the shipping from the states were its to much... Does anybody know some place were i can get this swap and not get f....d?
ejv8s10
Sep 3, 2014 11:52 AM
AaronGeisinger
Dec 17, 2010 08:57 AM
mikej94civex
Feb 7, 2010 05:40 PM
The King
May 2, 2004 09:24 PM
