how will my std handle with a b18a
Old Sep 8, 2002 | 10:04 PM
smashed4thgen's Avatar
Default how will my std handle with a b18a
i found the swap for 500 but it needs rebuilt so i was about ot do it but then i started to worry about my handling since the std dosnt handle that great anyways i already have h&r race springs and kyb gr-2 struts rear strut tower brace(front one wont fit right now cuz of dpfi)14 inc 4th gen si wheels w/toyo proxies ooh yeah and its simi gutted ..any thoughts on how it would handle with the ls engine in it and how i could improve the handling ///
mike
Old Sep 8, 2002 | 10:06 PM
EF_LSVtec's Avatar
Default Re: how will my std handle with a b18a (smashed4thgen)
Should handle fine w/current set up.
Old Sep 8, 2002 | 10:09 PM
Default not to duble post but
ive got a std hb with kyb gr2 struts h&r race springs rear strut tower brace and 4th gen si wheels w/proxies.. my question is when i am pushin it in turns it sounds harsh tire squell like a **** and dosnt hold as well as id like any suggestions???
Old Sep 8, 2002 | 10:23 PM
EF_LSVtec's Avatar
Default Re: not to duble post but (smashed4thgen)
Get better tires...
Old Sep 8, 2002 | 10:25 PM
marty's Avatar
Default Re: not to duble post but (EF_LSVtec)
Get better and wider tires.. riding on 185's will do you no justice. You might also want to look into stiffer suspension also.
Old Sep 8, 2002 | 11:06 PM
stiffer what else can i get besides better struts h&r race are supposed to be one of the stiffest i thought i dont feel any body roll..any suggestions on this and what tires would u recomend for daily driving??
Old Sep 8, 2002 | 11:09 PM
marty's Avatar
H&R's should do you ok... When I was riding on 14's I used ADVAN 032's but they're pricey. Some recommend Bridgestone S03 or Falken Azeni. But I personally like Yokohama AVS Intermediate.
Old Sep 8, 2002 | 11:19 PM
Default Re: not to duble post but (MugenEF7)
thanks alot for the advice iam goin to price them soon but i also an confused the more i think about the ls swap (will it be rewarding?) or should i try somthing new like d15b1 block a6 pistons y7 head springs cam valves and a 1st gen teg ecu //like most people iam not loaded and this car is my daily driver thanks
Old Sep 8, 2002 | 11:22 PM
the ls motor for 500 w/trans and ecu but i know i need other **** if i do it like shift linkage wiring convesion mount kit ect so this is why iam still considering a d series thanks
Old Sep 8, 2002 | 11:24 PM
marty's Avatar
ls... torque lovin
Old Sep 8, 2002 | 11:28 PM
have u done this swap befor if so could u tell me some about it ive read a lot about it bu it all seams veg id like to know about axles shift linkage hood clearance and dont u have to hamer the frame...also could u tell me a good but not expensive mount kit? thanks (i know this sounds stupid but i dont want to dump money into it if iam just goin to **** it up so i am goin to do it right and find out all the details thanks
Old Sep 8, 2002 | 11:39 PM
marty's Avatar
I havent done a LS swap over in a CRX before personally but have known people who have. HondaCRX whose a moderator can give you tips on wiring. As for mounting kits, HASport mounts and linkage kits are fairly priced. You might need to bang a little bit of the frame for the alternator clearance. Hood clearance is fine. Axles are used off any 90-93 Integra.
Old Sep 9, 2002 | 03:55 AM
FourthGenHatch's Avatar
Neuspeed Front Strut Bar will clear DPFI!!
I recommend Neuspeed Front, Rear, and Lower Tie Bar to stiffen up the body. Get a Suspension Techniques Rear Anti-Sway Bar and your car will handle much better.
Old Sep 9, 2002 | 05:39 AM
USDM 4G VTEC's Avatar
its not a matter of u haveing a STD
all civic mdoels have same suspension setup.. the only diff its that the Si has a rear sway bar...... u might wanna get a ghold of wider tires...... when i have my Steeles i can squeel onnturns bc they dont do ****...... with my 195 yokohamas AVID T4 i can do 55 on a curve and not hear a sqeel ...... also i go tNeuspeed springs, strut bars, and bushings..... just a pointer.....
Old Sep 9, 2002 | 06:54 AM
Audipwr1's Avatar
Default Re: how will my std handle with a b18a (JDM EF9)
id like to hear about the ls swap into a std hatch
more specifically wiring info
and what kunckles and axles to use with an s1 tranny
Jlamar757
Suspension & Brakes
May 10, 2006 08:40 AM
743power
Apr 3, 2003 09:09 PM
Digitalcivic
Dec 26, 2002 06:46 AM
neutron91
21
Nov 26, 2002 09:20 PM
smashed4thgen
Sep 9, 2002 07:35 PM
