RPM needle tweaking out???
Old Mar 20, 2010 | 03:28 PM
o_0's Avatar
o_0
Default RPM needle tweaking out???
Does anyone know why my rpm needle tweaks out when i pass 6k rpm? This just started happening out of nowhere. I have a 00 Ek hatch with Jdm Itr motor. I checked all the grounds and i have no loose grounds. What else should I check? It ONLY does it when i pass 7k rpm. So when i redline first gear, in second gear its fine, then after it passes 7k rpm again, it keeps tweakin out. Could it maybe be my cluster? I have a Si cluster that I've had for about 5 years now.
Also I have NO cel
Old Mar 20, 2010 | 07:43 PM
o_0's Avatar
o_0
Default Re: RPM needle tweaking out???
bump
Old Mar 21, 2010 | 04:39 AM
infinitypro12's Avatar
You have an ITR motor in a 00 Honda Civic harnessed with a different wiring scheme and ECU with an Si cluster, ha ha there are a few things that could be wrong. Sensors, ECU, or cluster would be the main offenders. If you can check with another cluster.
Old Mar 21, 2010 | 06:04 PM
o_0's Avatar
o_0
I'm using 00 Si harness running chipped p28 with itr base map. Well first i had this itr motor in my 96 ek hatch till i got rear ended, so i pulled the swap out and bought a 00 ek hatch. I changed my engine harness since 96-98 harness dont work. Everything works perfect on my 00 hatch but only problem is just the rpm. I had this si cluster on my 96 hatch and it worked perfect.
Old Mar 22, 2010 | 03:30 AM
Interesting indeed. Up, I have no answer, ha ha.
Old Mar 22, 2010 | 09:02 AM
RCurioso88's Avatar
Something similar happened to me. Whenever I floored it, the speedo will just go ape-****. I swapped an LSVTEC into my ej8 and what my problem turned out to be was my VSS. I swapped the metal gear (the one that goes down to the transmission) from a 'teg LS into my y8 VSS, which had a plastic gear. It fixed my problem. Good luck with it
Old Mar 22, 2010 | 11:21 PM
o_0's Avatar
o_0
yea speedo tweaks out cuz of vss. I dont think tach is messed by the vss. Someone told me since i have a 2000 civic, the dizzy sends signal to tach for the rpm, but I'm not 100% sure. They told me to maybe change the dizzy.
Old Mar 27, 2010 | 11:53 AM
o_0's Avatar
o_0
bump
Old Mar 27, 2010 | 02:11 PM
z6htch's Avatar
You are halfway correct. You need to replace the ICM, its located inside your dizzy. It sends a signal to your tach, and when they go bad, it will make your tach jump around giving you a wrong reading.
Its rectangular shaped and sits next to the coil. Hope this helps.
prelude2.2
Mar 3, 2012 01:35 PM
yellowjdmcrx
Oct 21, 2005 09:07 PM
96CivicBoostCoupe
Sep 12, 2005 02:02 PM
youlovebates
Feb 11, 2003 10:42 PM
