Another OBD1 conversion question.........and yes I did SEARCH
Old Mar 20, 2010 | 01:53 PM
EFRue57's Avatar
Default Another OBD1 conversion question.........and yes I did SEARCH
Okay pin A6 on the obd0 connector is for the purge cutoff solenoid valve. On a conversion sub harness I've looked at, it did not have a wire going from this location to the corresponding location to the obd1 ecu, which is pin A20. also on a friend's harness that the obd1 conversion that is built in like I am doing, he does not have this wire hooked up and both setups work fine.
I am just wondering why some write ups say to connect this and some say do not, and both seem to run the same. the searches I have come up with do not give a definitive answer as to if this makes a difference or not.
Old Mar 20, 2010 | 04:13 PM
Sikocivic's Avatar
Default Re: Another OBD1 conversion question.........and yes I did SEARCH
I am pretty sure that the cutoff solenoid valve is only found on the GSR intake manifold. If yopu don't have a GSR, don't use it.
Old Mar 20, 2010 | 04:22 PM
EFRue57's Avatar
incorrect, but thanks for the response.
Old Mar 20, 2010 | 04:23 PM
EFRue57's Avatar
here is what I'm talking about
Old Mar 21, 2010 | 10:02 AM
EFRue57's Avatar
ttt
98_ssbp
Aug 25, 2010 06:28 AM
cdndna
Feb 20, 2006 03:44 PM
650EF9HATCH
Feb 1, 2005 11:21 AM
Me2
Jun 2, 2004 08:00 AM
