Help: Trans
Old Mar 19, 2010 | 10:23 PM
todd217e's Avatar
Default Help: Trans
so i put a new clutch in, resurfaced the flywheel, new fluid, and i was driving the car, it was driving fine, then about an hour later i just lost all power like the clutch wasnt engaging, car went into gear but you could roll it forward and backwards when off and when it was on you could just stick it into gear but it would grind and just spin the gears it sounded like
any suggestions to what it could be?
Old Mar 19, 2010 | 11:05 PM
todd217e's Avatar
Default Re: Help: Trans
this is like the ek from hell, first it was burnt exhaust valve from some ricer i bought it from and now trans problem, what the hell
Old Mar 19, 2010 | 11:52 PM
e hahai's Avatar
check on the front of the trans to see if the clutch fork is loose. if it is; probably the clip holding the fork to the trans housing came off.
Old Mar 21, 2010 | 09:38 AM
todd217e's Avatar
hahaha, well it was the dr side axle, popped out, thank god
kgcivic88
Transmission & Drivetrain
Jun 23, 2011 08:36 AM
Will_H
Sep 4, 2008 08:32 PM
g2tegsown
Jul 15, 2007 07:36 AM
kordenbrock motorsports
May 31, 2006 06:53 AM
crizx
May 19, 2006 09:51 AM
