boost on automatic transmition comment pls
Old Mar 19, 2010 | 07:45 PM
titi_vtec's Avatar
Icon2 boost on automatic transmition comment pls
hey i have a friend with same car like mine he got a 99 ex, he has automatic transmition and he want to go boots, it can be possible? what do he has to do with it? please give opinion really interesed on this
Old Mar 19, 2010 | 07:51 PM
alphalanos's Avatar
Default Re: boost on automatic transmition comment pls
It can be done but they cant handle much. Highly advise a manual trans swap.
Old Mar 19, 2010 | 09:39 PM
ReVeNgEd-SoN's Avatar
Boosting a automatic so pointless and worthless. Get a manual.
Old Mar 21, 2010 | 12:19 AM
em1effekt's Avatar
tell him to sell it..
Old Mar 21, 2010 | 01:26 AM
Ruben19's Avatar
tell him not to waste his cash
Old Mar 21, 2010 | 03:51 AM
rexload's Avatar
7X10 transmission oil cooler from summit - about $50,
flush the tranny fluid when you change oil,
keep it under 200whp,
it should last a good while
Old Mar 21, 2010 | 03:26 PM
94EG8's Avatar
Seagull Management
It can be done with an AFC controller. Its going to be a hack, and its not going to last. You can't run an OBD1 ECU with an OBD2 civic tranny. You pretty much have to swap in a 5 speed and convert to OBD1 to do it right.
Old Mar 21, 2010 | 05:00 PM
apexi_rsx's Avatar
SAFC and a msd BTM (boost timing master) is the best combo to use OBD2. i would deffinately run a oil cooler with a fan n thermostat. i ran mine this way for a while. since you dont have a filter. it will cook fast and u will have to change ur transmission fluid every 10-20k. 3.5 quarts to fill. id flush it before u even put the turbo kit on.
Old Mar 21, 2010 | 05:16 PM
300whpej's Avatar
i think the tranny and ecu would take a massive inconvenient **** on themselves
Old Mar 21, 2010 | 06:31 PM
Schister66's Avatar
Man U FTW
There are 2 inherent problems with the auto tranny:
1. The transmission is not built to handle a lot of power. If he's set on doing this, i would advise a tranny cooler as mentioned above
2. Tuning the automatic is going to be a pain in the ***. I'm not sure which, if any, programs will work for this application. At this point, a manual swap is a much better option
Old Mar 22, 2010 | 06:52 AM
titi_vtec's Avatar
hey friend thank a lot, he read all of your msg and help him i tink so, thanks for everything
duceducecord
Jan 30, 2014 10:12 AM
Stevoyayaya3
Transmission & Drivetrain
Aug 2, 2012 02:55 PM
Fendyc718
Feb 18, 2011 03:51 PM
screen_name
May 14, 2009 05:25 PM
oldskooljdm
Mar 28, 2005 04:38 PM
