LS-VTEC cannot set timing
Alright, so swapped an ls-vtec in the CRX. I'm running a GSR basemap on a chipped P28.
First time I had it running, mechanical timing and distributor timing were fine, I just had to retard the distributor all the way.
Had to take it all apart for a couple BS reasons, put it all back together the same way it was, but when I retarded the distributor all the way and it's still not retarded enough... Mechanical timing is perfect. Any ideas?
if you are having to retard the distributor, then I think mechanical timing is not 100% on. On our last LS/V our distributor was not retarded (i always laugh when I type about that, lol) at all. you might be off a tooth. try setting your timing belt back 1 tooth.
I mean...I can take pictures if it wasn't so dark. The two notches on the cam gears are pointing directly at each other. The notch on the crank pulley is pointing directly at the notch on the timing belt cover...well it's about 1-2mm forward of it but definitely not a full tooth off, and I can move the crank pulley back every so slightly so it lines up with the notch and the cam gears are still where they should be.
how did you set the block at lsv is the block milled if so it may be off with a lsv it might be in your interest to get good quality adjustable cam gears to time it like EFRue57 your may be a couple of teeth off
Yep used a timing light. When it flashes, the middle timing mark is about an inch in front of the notch on the timing belt cover.
Why I don't understand was how I was able to get it timed properly last time, and nothing has changed this time I put it together, but I can't retard the distributor enough.
Even though cams and crank pulley all line up properly, would it hurt to turn the crank back a tooth to where the cam/crank don't line up and see how it runs?
I may just adjust the whole basemap back a few degrees although I don't see why I should have to when it worked perfectly fine last time...
Yep actually have the wires ran to the engine bay to a switch just to make it easier.
The ECU tries to compensate but can't quite it it there.
Was suggested I double check that the cams aren't mixed and that the key in the pulley is there/good, but open to any other ideas
Just to put the "mechanical timing is off" thing to rest, here are pictures:
Unless I'm completely wrong, that's how it should be, which is why I don't understand retarding the distributor all the way and it still not being enough...
Yes I'm jumping the service connector. It's more stable than without it jumped but still about an inch forward of the notch on the timing belt cover. I know that it's properly jumped because the CEL is solid when I start the car.
When using the timing light, the BTDC notch is showing up about half the distance between TDC and the BTDC notch.
is their n e way the rotor some how moved or slid inside the dizzy like as if the screw hole ovaled ???? it would still work but it would deff throw the timeing off
Rotor is where it should be and tight.
I have spark plugs like this:
34
12 4 3 2 1
I took the cap off the distributor to make sure the rotor was near where the cyl 1 wire is when it's at the btdc mark.
34
12 4 3 2 1
have you checked to see if you are getting spark to all 4 cylinders? sorry to keep asking a bunch of questions I'm just trying to do a rundown of possibilities.
Here's the latest. Put the mechanical timing back to where it was. It starts and runs, put all brand new plugs in and with the timing light I can see that a couple start firing erratically after less than a minute. Ignition timing is still a little too advanced.
It starts crappy, low RPM, gets better as it runs, then suddenly dies after a few minutes.
Put a screwdriver to each injector/my ear and could hear them opening like they should so...
