Radiator Cap= OVERHEATING ISSUE?
Old Mar 19, 2010 | 11:20 AM
Neo218's Avatar
Default Radiator Cap= OVERHEATING ISSUE?
I was wondering if a bad radiator cap could cause an overheating issue?
Old Mar 19, 2010 | 11:31 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: Radiator Cap= OVERHEATING ISSUE?
i heard it can if there is no spring in it to relieve pressure to the overflow..(actualy causing too much pressure)
Old Mar 19, 2010 | 12:55 PM
Red_Army's Avatar
otherwise no. id blame your tstat.
Old Mar 19, 2010 | 01:05 PM
Relic1's Avatar
yes it can.
both ends of the failure mode.
not releasing the seal - too much pressure in the system causes something else to fail and leak = can overheat
releasing the seal too early, or no seal - too little pressure, pressurizing the system causes the boiling point of the water/coolant mix to increase, helping with heat removal from the engine. no pressure and the engine can develop air pockets with steam = overheat in the worst way.
it's an easy & cheap swap out just in case that's the issue. If that doesn't fix it, go with thermostat.
Old Mar 19, 2010 | 04:59 PM
98civdx's Avatar
Master Detailer
^^ what he said.
Old Mar 19, 2010 | 05:17 PM
h22a4_sol's Avatar
Originally Posted by Relic1
yes it can.
shiiit you cant get a better explanation than that.
Old Mar 19, 2010 | 07:39 PM
titi_vtec's Avatar
yes it can i have the same problem with my first civic, it has a sprint inside that when it has to much presure it open and take water of the little bottle or return it but when you dont have presurre it get hot, change the cap and problem solve
soon2bdropped
Oct 17, 2007 10:10 AM
luis666
Feb 4, 2006 03:19 PM
mickey513
Oct 11, 2004 06:51 AM
bryan305
Jun 10, 2003 04:30 AM
92SiB18C1
Apr 9, 2003 06:40 AM
