H23 motor swap help
Old Mar 18, 2010 | 08:24 PM
(95EG8)'s Avatar
TRIAL USER
Default H23 motor swap help
ok, so i have 95 civic 4dr and i want to swap in an h23 thats in my honda prelude. i don't know alot about how do to it or what i need, any advice helps. Thanks!
Old Mar 18, 2010 | 11:25 PM
hickle's Avatar
Default Re: H23 motor swap help
really not trying to burst your bubble or be mean, but if you have no clue how to swap an engine whatsoever i wouldnt try to swap an H motor for your first one. theyre a bit more difficult than say a B engine or another D engine swap. but if you think you can, go for it! thats just my .02
a couple things youll need for any swap: block, head, tranny, intake manifold, a correct throttle cable, axles, shift linkage, ecu. theres other things you need too but theres plenty of info on here about what you need for what swap. good luck with whatever you choose to do!
Old Mar 19, 2010 | 01:31 AM
HondaPartsHero's Avatar
Technical Hero
https://honda-tech.com/forums/hybrid-engine-swaps-18/%5Bfaq%5D-%2A%2A%2Ah22a-into-civic-eg-ek-information-post-all-h22a-hybrid-info-here%2A%2A%2A-650329/
https://honda-tech.com/forums/hybrid-engine-swaps-18/additional-h22a-civic-axle-information-434668/
Old Mar 19, 2010 | 11:42 PM
(95EG8)'s Avatar
TRIAL USER
i also have a person to guide me who has done all this fun before. so i have the prelude thats all put together. other than what i have right there, what do i need
Old Mar 20, 2010 | 08:11 AM
CivicSpoon's Avatar
You will need to read the 2 links HondaPartsHero posted. The H23 swap is the same as the H22A swap, minus some wiring. You're also going to need an aftermarket mount kit and axles (either custom or modified ones discussed in that 2nd links H.P.H. posted).
Old Mar 20, 2010 | 08:18 AM
92civlude's Avatar
Having a donor car (PRELUDE) makes it easier. You have the shifter,cables, ECU, trans, The H23 wiring is painless. Use the civic wiring to fit the H23.
Old Mar 21, 2010 | 11:48 AM
(95EG8)'s Avatar
TRIAL USER
i have a prelude thats all together. but i just need to get it running. will the prelude axles work? and will the exhaust fit under my car? now as of today my clutch went out in my civic and i need it to drive every day. anyone know where i could order a cheap clutch?
bukhumlae
Jul 13, 2007 10:00 PM
EnSAn
Jul 29, 2006 08:28 PM
x8_andrew_8x
Jan 28, 2006 04:18 PM
folta2169
Dec 16, 2004 09:59 PM
