Fuel line removal diagram
Old Mar 18, 2010 | 05:59 PM
Tru3nV's Avatar
Default Fuel line removal diagram
Hey Honda-Techies. I need a diagram/pictures/or write up of how to remove and replace a fuel line. The fuel line that comes from the Fuel tank and connects to the fuel filter.
Thanks,
Tru3nV
Old Mar 18, 2010 | 06:16 PM
Luserkid's Avatar
Default Re: Fuel line removal diagram
Its a pretty straight forward task. Drain all the gas from the drain plug. Then undo the line from the banjo line under the car to the tank, unhook the filter and then follow the line while unclipping it from the brackets all the way to the back to the tank. After that drop it from the tank side first then gently pull through the subframe. To reinstall do it backwards. If its to much of a pain to put it back through the subframe then lower it a little by removing the 3 bolts on the driver side and loosen the 3 on the pass side. Should give you enough space. You didnt mention what year but this would work for all 92-00 Civic.
Old Mar 19, 2010 | 09:15 AM
Tru3nV's Avatar
Thanks luser kid.
I'm removing a broken fuel line from a '93 civic dx and removing a good fuel line from a '93 civic ex. Reinstalling the good fuel line to the dx. If anyone has pictures it would help me out a lot more.
Thanks again,
Tru3nV
hoytheld
May 16, 2014 02:12 PM
EK9r!der
18
Aug 23, 2012 09:57 PM
jdmjin
Jan 2, 2008 07:29 AM
JLefevers
Jan 1, 2008 09:20 PM
spun311
May 18, 2007 03:26 AM
