2 of header pipes not getting hot
So i'm almost done with my h23 to h22 swap and i started it up and 2 of my header pipes werent glowing and werent hot, i was hoping i didnt burn my valves when i started it and rev'd it without a downpipe and exhaust on. i also have not finished hooking up my vtec, not sure if that has to do with it, and i am running a p13 ecu,
MUCH HELP NEEDED
thx,
gorthjr
MUCH HELP NEEDED
thx,
gorthjr
ok its the left 2 that arent getting hot, and theyre new stainless steel headers, the right 2 dont glow, they got an orangish tint or light red when they heat up, the other 2 stay completely normal.
Does your engine run even? I had a case when one of the injectors was not powered so no burning mixture. The result was three header pipes where different colour than the last one and the engine was thumping.
you mean, "does the engine run correctly", its obviously firing
yes the engine starts and remains running, sounds like its bogging out a bit, but i think thats because some of my vacuum hoses arent hooked up right, and would the vtec not being wired cause 2 of the pipes not getting hot
yea vtec wouldn't cause cylinders to fire...
how bout you take a picture of these so called glowing headers for us. When i first swapped over my h22 one cylinder wasn't firing cause the injector was clogged.
ok they dont nessesarily glow, the crome turns into a light copper color. not like a bright red, but yeah i will definitely send u a picture after i get off work.
and how much would it cost to unclog my injectors if thats the case
or just buy new ones?
if it is stainless...you are probably just seeing it change colors due to the heat....which is normal. rc engineering will clean the injectors farily cheap.
thanks guys so much, and no, it was idling at 2k, i wasnt getting power to 2 of my injectors, i followed the plug and it wasnt fully clipped in. runs and sounds normal now
