need a parts list for jdm b16a sir2 in 90 crx si
i have a jdm b16a sir2 in my 95 hatch that i want to swap in my 90 crx si. can i reuse the axles im using now? what will i need for cable to hydro conversion since i have a hydro tranny right now. i need to know all the parts involved to make this happen.
well first of all motor mounts.
cable tranny if you dont do a hydro conversion.
if you wanna run the obd1 ecu you have to convert to obd-1
what else..
DA rear T bracket.
and half shaft and axels???
hmm
what else..
DA rear T bracket.
hmm
1.is this the right conversion harness? i see that he makes two different ones and one is $100 and this one is $190
2.can i reuse my axles?
3.whats this DA rear t bracket you speak of?
4. hasport efb2 mounts?
