AWD civic possible?
Old Mar 17, 2010 | 09:23 AM
blueblur1984's Avatar
From: Marin county (aka death's waiting room), SF bay area
Default AWD civic possible?
This is a long shot but I thought if anybody would know they'd be on here. I probably should've started this on the ef forums but I'm more concerned if it would translate to my ek.
I know the civic station wagons back in the late 80's had all wheel drive (or 4wd...I forget which). I was wondering if the awd components could switch over to the old ef civic hatch or my civic ek coupe. I haven't seen it done before so I'm guessing it's either impossible or there is some kind of limitation with the 4wd system that would keep it from being fun to drive, but if anybody has a link to someone that has done it or has any input on why it would/wouldn't work I'd appreciate it.
Old Mar 17, 2010 | 09:33 AM
Default Re: AWD civic possible?
PS I forgot to mention I did find an AWD thread here but it was using various CRV bits or making a custom drive shaft and rear end. I was hoping I could just buy a late 80's civic wagon for a couple of hundred bucks and swap out a few parts. I imagine the older civic wagons still used D series motors right?
https://honda-tech.com/forums/welding-fabrication-53/serious-awd-conversion-thoughts-1143469/
Old Mar 17, 2010 | 10:43 AM
Red_Army's Avatar
not without doing a custom drive shaft and rear housing and redoing the whole rear end. it was done that way because i imagine it was the only or best way to do it.
how exactly did you plan on driving the entire back end with no driveshaft or rear end work? since a normal civic isn't built for either.
it is possible but not cheap unless you can do alot of it yourself.
Old Mar 17, 2010 | 11:41 AM
98civdx's Avatar
Master Detailer
with the right amount of money and the right knowledge anything is possible.
Old Mar 17, 2010 | 01:32 PM
fungus mungus's Avatar
There were AWD EG Ferios in Japan: RTX
Also the RTSi model
fm
Old Mar 17, 2010 | 02:03 PM
Thanks fungus mungus! I figure swapping over parts from a comparable model would be easier than trying to piece something together from several different cars. Still might be a pipe dream with the limited budget I'm willing to put down on this but at least I've got a starting place.
Old Mar 17, 2010 | 08:16 PM
There's someone in the Bay Area selling a real RTSi legally registered in California for 10K. If I didn't have a wife, I'd be all over it.
fm
Old Mar 18, 2010 | 08:10 AM
Lol, always the way it goes. I took some crap for having a short shifter delivered to the house. Guess I have to send parts to the office from here on out.
Old Mar 18, 2010 | 08:37 AM
Red_Army's Avatar
haha really?
yell at her for having craft stuff delivered to the house way down the road.
just wait till you start ordering big parts. that'll be a fun day.
Old Mar 18, 2010 | 09:08 AM
LOL...I just took delivery of a JDM ITR header...at the office.
fm
Old Mar 18, 2010 | 09:12 AM
Old Mar 18, 2010 | 09:16 AM
apexi_rsx's Avatar
double post ***** =oO j/k
Old Mar 18, 2010 | 11:42 AM
andoxviii's Avatar
I remember reading up on this a little while back. The D-series 4WD components from the wagon you are referring to are crap. Apparently they are pretty weak and can't hold much power, which makes engine-building an impossibility. And I think something like 10-20% of the power goes to the rear, and the other 80-90% is at the front.
The CR-V system for B-series motors is much better.
Old Mar 18, 2010 | 12:08 PM
JBrettHowell's Avatar
Not an EG, but here is an AWD Turbo Civic for sale: http://sccaforums.com/forums/thread/400737.aspx
Old Mar 18, 2010 | 12:27 PM
newtron63h's Avatar
either way, it would still need some custom fabricated parts which are going to be expensive.........and if they break.....it will be expensive again.
Old Mar 19, 2010 | 01:52 AM
NOFX's Avatar
H-T White Ops
Yes, there were AWD 3G Integras, 5G Civic sedans and 6G Civic sedans.
NONE of them were really performance oriented. All of them came with what was damn close to a FWD drivetrain too. 70/30 really isn't anything awe inspiring.
The problem I see with trying to convert a '92-'00 Civic or '94-'01 Integra to AWD is that there really isn't any Honda or Acura drivetrain that is good enough and would be able to fit without a load of customization.
If you really want to make a performance oriented AWD '92-'00 Civic or '94-'01 Integra my suggestion is to get really good at figuring stuff out, get a nice big budget, get lots of tools together and figure out how to make some Subaru parts fit on your car. One of the original AWD chassis might save a little time in customization, but getting it here would just cost more cash and time. Then all you'd really be getting is a "better" chassis, which you would still need to put a lot of work into and otherwise cut up.
I would imagine you'd be pretty well off using first gen Impreza parts (some older Subaru parts might be cheaper, but harder to find in good condition) and putting them in the Civic. But then you'd have to get everything to match up to your D/B-series engine and mount the drivetrain in your car. At this point you're probably wondering, "Why not just buy the Impreza straight up?" And that would be a very good point.
And yes... Yes, "anything could be done with enough time, money, energy and knowledge", but that might as well get posted in damn near any thread on here. It's a good way to up your post count but doesn't really teach anyone anything or add anything to the thread.
Old Mar 19, 2010 | 06:11 AM
With all due respect, While I agree that the JDM AWD Civics weren't performance cars, the OP never mentioned anything about building a performance car. He just asked if it was possible to make an AWD Civic. Not if it's possible to build a Civic STi.
fm
Old Mar 19, 2010 | 08:07 AM
FRESH.EJ1's Avatar
lol @ civic STi
Anyways, it would be a lot less hastle trying to go RWD than AWD for the civic though (at least in ease of parts accessibility) because you can swap stuff with the S2000, and i think the guy who did RWD to his hatch had s13 diff/subframe and everything (correct me if im wrong). But either way, you will have lots of cutting/custom work. Plus massive firewall raping to fit the gear box in lol
And yes, if you want it that much its possible for AWD.
Old Mar 19, 2010 | 08:52 AM
HELLAxJEWCED's Avatar
TRIAL USER
one kid at my h.s. was always talking about building one!
Old Mar 19, 2010 | 01:02 PM
NOFX's Avatar
H-T White Ops
fm
I understand this.
Since he specifies he wants it as a certain model year that here in the states never came with AWD (even though earlier models came with it), then I have to imagine the newer car has something about it that he prefers over the older car.
Probably something big since, well, otherwise he'd just go for the car that is readily available.
Being Honda-Tech, this means he probably wants something showy of some sort (whether it's truly visual, or bragging rights, or wanting to look/be impressive, etc.) or finds some redeeming quality about the 6G (interior, exterior..?). It's not like the 4Gs are non-functional vehicles or anything. There isn't a lot about the fourth gen that is lacking in comparison with the 6G when you're talking about just wanting a car to drive. I find it difficult to believe he is just that enthusiastic about the '96-'00 coupe, but dislikes the drivetrain.
In fact:
Originally Posted by blueblur1984
Hey everybody, not new to cars but I just sold my 10ae miata and picked up a 96 civic ex for $1200. All in all it's in pretty good shape but there are a few things that it needs/ I want to do.
On a side note I'm looking for mods that will make the car more fun to drive but not attract attention (no mufflers, body kits, etc). I'm thinking strut braces, stiffer shock (hopefully something close to stock ride height), short shifter...any input would be appreciated.
This, to me, sounds like the OP wants a car that he sees as more fun to drive. This might include going AWD.
The OP might very well change his mind when he sees how incredibly difficult it is to swap a 5/6G Civic in the US to AWD. Plus it's not going to make it anymore fun to drive at all.
Old Dec 15, 2011 | 11:31 PM
EGscrapyard's Avatar
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/my-95-civic-hatch-project-3006609/
Old Dec 16, 2011 | 01:04 AM
kingyeddi's Avatar
thread from the dead.. theres a guy at dso that just finished an awd Civ using CRV parts
bfraley
22
Nov 5, 2014 09:42 AM
krugozor
19
Jun 23, 2013 08:00 AM
davegt27
Sep 3, 2012 07:19 AM
bluedevil
Sep 15, 2007 04:35 PM
JasonGhostz
10
Aug 27, 2005 08:40 PM
