GMB Water Pump for Honda Accord 1994 EX F22B1
Old Mar 17, 2010 | 04:58 AM
faran's Avatar
Icon6 GMB Water Pump for Honda Accord 1994 EX F22B1
Techs,
I am planning to do a Timing belt job on my Honda Accord 1994 EX F22B1.. I have a GMB water pump I was wondering if some one would have any experience with those pumps or at least any feed back or input regarding those pumps that are they reliable and long-lasting as I am planning to install it during timing belt job.
Any input would be appreciated
Old Mar 17, 2010 | 07:32 AM
GhostAccord's Avatar
Default Re: GMB Water Pump for Honda Accord 1994 EX F22B1
I used one the last time I did the timing belt change on my F22B2. When I tore the motor down, 2 years later, it was still in good shape. I'll be using another one on my new build as well. The only thing I read was that you are better off to buy an OEM water pump o-ring/gasket. Honda part # 19222-PT0-300. The GMB ones are known to have sealing issues. Use the Honda gasket and torque it to the specified specs and your good to go.
Old Mar 17, 2010 | 07:52 AM
faran's Avatar
How about that sealant should I use any sealant or only that HONDA OEM gasket would be suffice also can any one tell me how to install the Crank, Cam and balance shaft seals as almost every day I am seeing oil under my car this weekend I have to find where it is leaking from!
Also those seals do they require any sealant or grease??
Any help would be greatly appreciated!!!
Old Mar 17, 2010 | 08:49 AM
PM sent!
aschweizer2007
Sep 21, 2018 07:22 PM
bcdinh
May 4, 2012 01:06 PM
Daisysi
Southeast
Jan 8, 2008 06:57 PM
Stew Pidasso
Jan 2, 2008 04:41 AM
lunaar
Aug 21, 2006 04:44 PM
