Make $20 fast if you have a chasebays brake tuck EG/delsol
Old Mar 16, 2010 | 07:42 PM
Ty.'s Avatar
Ty.
Default Make $20 fast if you have a chasebays brake tuck EG/delsol
make $20 easy! read
Im currently trying to install a chasebays steel braded brake line tuck kit. The kit did not come with any directions and i searched long and hard for a write up or even some pics of someone elses setup. I need to know where about i should drill holes through my firewall. i got 2 real short lines that i thing go in the fender well of go to the rear brake lines? im not sure
PICS SAY A 1000 WORDS
I will paypal $20 to the person with the best write up that helps, also it will help other people install there kits and maybe even help chase sell more kits.
Thanks in advance.
Ty.
Old Mar 16, 2010 | 08:16 PM
geneeunit's Avatar
Default Re: Make $20 fast if you have a chasebays brake tuck EG/delsol
"The install is very easy, just drill the holes for the bulkheads, hook up and run the -3 line, and flare the rear lines low on the firewall to a 37 degree flare (flare tool rental available)"
i assume you can run your lines where ever you please.. it would be just like any other brake line tuck, but instead of using hardlines you're using some stainless lines.
check out this thread to gain more knowledge..
https://honda-tech.com/forums/honda-acura-28/shaved-tucked-customized-engine-bays-pics-theory-discussion-1693934/
but basically.. you run those two lines to the prop vavle.. and from the prop valve they go to each individual caliper.. how you hide them would be your decision i believe. just think of it as relocating the prop valve.
Old Mar 16, 2010 | 08:39 PM
Ty.'s Avatar
Ty.
i have that much done on mine, and ive read through that entire thread several times. i just need to know what lines to go where. they are all diff lengths for a reason so they should fit like a puzzle. i just need directions for the puzzle or pics.
thanks for the quick reply though
Old Mar 17, 2010 | 06:01 AM
Ty.'s Avatar
Ty.
pics of each wheel well, under dash right, left,center, and firewall where rear lines come out would sufice!
Old Mar 17, 2010 | 07:43 AM
HondaPartsHero's Avatar
Technical Hero
Why don't you contact chasebays?
Old Mar 17, 2010 | 08:27 AM
Ty.'s Avatar
Ty.
from some of the other threads on here it sounds like they are busy over there and it would be a while to get a reply, was hoping someone with the tuck could just take 5 min to take some pics
Old Mar 17, 2010 | 12:10 PM
Ty.'s Avatar
Ty.
TTT
Old Mar 18, 2010 | 05:57 AM
Ty.'s Avatar
Ty.
HEADED TO CABO BUMP
Old Mar 18, 2010 | 08:33 AM
geneeunit's Avatar
im assuming longer lines for the front, shorter lines for the rears.
since the fronts have to be tucked away.
Old Mar 25, 2010 | 02:44 PM
Ty.'s Avatar
Ty.
There are 8 lines
Old Mar 25, 2010 | 04:13 PM
ekSedanB16a2's Avatar
contact the company bro. they will be the only ones who can give you a 100% correct answer. good luck tho son post pics when done!
Old Mar 26, 2010 | 10:17 AM
Ty.'s Avatar
Ty.
Emailed chase. We will see
Old Apr 6, 2010 | 07:11 AM
Ty.'s Avatar
Ty.
made my own write up. will post up in the next few days
Tippyman
Jun 3, 2013 07:17 PM
ESP.net
Suspension & Brakes
Jun 1, 2010 09:00 PM
Whatislove
Honda Civic (2001 - 2005)
May 19, 2009 05:41 AM
Redline96LX
Jan 6, 2006 06:05 PM
Flux
May 27, 2003 07:48 PM
