needs for B16 swap
one of my buddies got the complete B16 swap from the 99 civic si which he wants to put in his 95 civic DX.
im not too sure with what its needed for the swap in a EG but from what i know is the B-series mounts,94-01 teg shift linkage and vtec harness will be needed and the stock ecu from the Eg might get chipped for the B16 so yeah thats about what i know.
i need some advice if im missing something here. also, are the obd1 fuel injector plugs the same as the obdII ?
yes, you will need dc integra (94-01) mounts (3bolt driver), shift linkage, re-pin the dizzy plug, re-pin the alternator, use the obd1 injectors, you can use the dx engine harness and wire vtec to the shock towers the legit way or run the wires straight to the ecu. if you use the halfshaft from the si, then dc/em1 axles. you can also use the dx throttle cable, you will just need to reposition how it sits on the manifold. thats really about it other than little things like fluids, and tune up items.
EG*5*CIVIC
14
Dec 12, 2014 05:05 PM
