93 ex with d16y7
can someone tell me if this http://www.phearable.net/tech/wiring...istributor.jpg is the correct dizzy wiring for obd2a to obd1 cause i just wired it that way and it going into limp mode and the tach isnt working.
there was one wire that was a different color it was TDC+ they said green and i had a orange/blue left so i wired that to green
or should i go try this one https://honda-tech.com/forums/acura-integra-6/diy-obd1-obd2-distributor-conversion-harness-1876307/
thanks for any info
*oh im using the d15b7 ecu
thanks for any info
i got that figured out i swapped the light blue for the dark blue so now the light blue is the tach and now i got a code 43(fuel system) dont know if it has anything to do with the dizzy wiring or not
ryan_1014
Nov 12, 2010 07:31 AM
95f22a1
22
Feb 2, 2009 10:12 AM
