Installng New MC and Calipers - Flush or Drain?
I'm installing new front calipers and a new master cylinder on my 93 accord lx. What I'm wondering is, should I install all the new components and then do a complete brake fluid flush? OR should I just let the front brake lines drain while the calipers are off, bleed the front lines through, and then flush the rear lines?
The reason I ask is, if I flush the lines with the new calipers installed, won't that be pushing the gunk in the lines through my new caliper piston cylinder?
Opinions welcome.
Opinions welcome.
Well, you should follow the correct instructions for bleeding. It's not just bleed the fronts then bleed the rears. There is an order to it.
You are going to introduce air in the lines by putting on new calipers and the MC. Just get one of the nice air bleeders if you have access to one and go to town and do it all at once. I wouldn't worry about draining the lines prior to installing the new calipers.
If I do flush out the old fluid with new, I would certainly follow the bleeding order.
My concern though, is if I push out the old fluid through the bleeding nipples on the new calipers, won't that introduce gunk from the lines to the inside of my brand new caliper piston cylinders?
I'm replacing the calipers because both are leaking at the piston seals, and judging by the condition of the rest of the fluids in the car when I bought it recently, I'm guessing that the brake fluid is ancient.
it goes without saying that you should use a nice high quality fluid... whatever brand you prefer
I personally would do ATE Super Blue Racing DOT4, but Castrol GT-LMA is also a nice choice that is slightly more affordable
NitrousB.I.G.
Jan 11, 2006 10:07 PM
