FT 86 Mazda RX-7
I have a base model Mazda RX-7 I want to trade for a 92-95 civic coupe (ex prefered) or hatch, or a 94+ integra. must be 5 speed, any milage is fine, must run, and have very managable rust. Black Interior also wanted, but grey is acceptable too. Maybe blue...
The RX-7 has 167k mantained miles. Currently has new oil/oil filter, plugs, wires, belts (not timing), and a new alternator, and a radiator house was replaced. The car only really needs a Clutch Slave Master Cylinder. Unlike a honda, its not that easy to get too, and since my friend refuses to help work on it, I can't afford a shop to do it (im unemployed, my friend excepts trades for stuff), and I want something that I won't play around in too much. The car is Gold/primer, no major rust, just some surface. A few dents, a nice Turbo II aluminium lightweight hood. Retarded Mufflers (they can be cut off, and new ones welded on, or a newer, nicer exhaust can be gotten). It is 4 lug, and i belive are also 4x100. The tires are bad as well. The car does run, but I can't prove it. The battery died, I swapped in another that needs charged. I pop started the car the first time since the motor flooded on me, as these cars can do that with the stock setup. There is a forum as well that tells you anything, and everything about these cars.
All pictures are located here:
http://s7.photobucket.com/albums/y276/Atomsk4990/RX-7/
The black car with the gold hood is a Turbo II parts car (strickly parts car) thats for sale seperatly for $400.
djedd
41
Dec 6, 2015 08:12 AM
