Replace or Rebuild?, Lude on its last leg. (almost)
Old Mar 16, 2010 | 03:46 PM
Rockstar21's Avatar
Default Replace or Rebuild?, Lude on its last leg. (almost)
sorry if there is a thread that applies to my question. im not familiar with how to get the H-T search to function correctly yet.
my 98 SH has almost 200,000 miles on it as it stands right now.
its running reliable, but with lots of power loss/smoke/small oil leak.
but again.... reliable.
compression was between 145-155 throughout all 4 cylinders.
i have the money for either a rebuild or a new motor swap. but im unsure as to what direction to take it.
its a bit tougher to find an h22a4 for the SH as i understand and i have a shop in the area that can rebuild my h22 completely for around 2k.
would it be a wiser/cheaper choice to try and find a replacement low milage motor, or rebuild mine from the ground up and get it running close to new again.
my apologies again if this is a re-post.
Old Mar 16, 2010 | 05:25 PM
ilikehonda's Avatar
Default Re: Replace or Rebuild?, Lude on its last leg. (almost)
id run a compression and leak down test first before you do anything.
if it were me id find a low mileage replacement.
Old Mar 16, 2010 | 05:32 PM
street_ride14's Avatar
Rebuild, but choose this option only if you are planning to rebuild yourself and not have a shop rebuild for you. I don't trust local shops with engines.
If you can't work on this car yourself, then you'de be better off having the shop swap out your current engine with another lower mileage h22a4.
Old Mar 16, 2010 | 06:45 PM
Rockstar21's Avatar
Old Mar 16, 2010 | 07:56 PM
autoluder's Avatar
its always more reliable to swap the engine out for a another engine exactly as honda made it, untouched by anyone else. I picked my long block from a reputable engine supplier for 900 bucks..
Old Mar 17, 2010 | 11:32 AM
Rockstar21's Avatar
i've spoken with a few, but the ones i've talked with seem to have an issue finding a Motor that was paired with an ATTS.
they have tons of base model engines.. care to share your supplier?
Old Mar 17, 2010 | 11:35 AM
NirVTEC's Avatar
Its a tough call. While I love a stock, never cracked open Honda motor, a very well rebuilt motor should be just as good. Thing is most places are so clueless on FRM that unless I knew for 100% sure that they had major FRM experience, I would rather have a 40-60k JDM Mystery motor for >$1,000
That being said, I think you're screwed b/c its an SH motor......G/L finding a decent used one.
Honda S2000
May 9, 2017 11:53 AM
Acura850.
Feb 11, 2009 12:18 PM
Integra_chick95
Aug 11, 2005 12:00 PM
c1civic
22
Apr 12, 2005 05:52 PM
obd1gsr
Feb 18, 2004 07:58 AM
