Replaced struts several months ago and now squeeky noise
Old Mar 16, 2010 | 03:38 PM
pityocamptes's Avatar
Default Replaced struts several months ago and now squeeky noise
I must be a glutton for punishment as I embark on fixing all the **** wrong with this car, can't complain though... hopefully it will last another 12 years!!
Anyway, I replaced the struts several months ago, but reused the rubber pieces that the spring mounts to at the top of the tower. Could that be causing the irritating suspension squeek?
(Not too cool when you go on dates... )
Old Mar 16, 2010 | 07:41 PM
96hb's Avatar
Default Re: Replaced struts several months ago and now squeeky noise
It could be your upper control arm bushings and/or ball joint. That's where the noise is coming from on my car at the moment. Have a look at yours to see if the boots are ripped or smashed.
Old Mar 16, 2010 | 07:54 PM
S_F's Avatar
S_F
I have also experienced suspension squeak from a bad ball joint. I also had a squeak that sounded like it was coming from right under the strut tower. Fixed it by soaking the area with penetrating oil to clean it and later applying a lubricant.
Good luck. Those noises blow.
Old Mar 16, 2010 | 09:18 PM
ap1 george's Avatar
Does sqeaking come when you bounce? If so then try tightening your control arm bushings.
Old Mar 17, 2010 | 09:41 PM
BuildTheDream's Avatar
Haha I remember those days, mine was from the sway bars though. I finally just said screw it and got rid of them when I got coilovers.
Old Mar 18, 2010 | 09:39 AM
Tried the lub on the upper rubber part where the coil seats. It did quiet it down a lot, but when the lub dried out it came back. Seems to get worse when everything gets wet from rain. Funny thing is the noise never happened until I changed out the struts. Hmmm, maybe its time to get a new set of those rubber mounts that the coil seats into.
MechEng
Feb 18, 2015 05:58 PM
fedex
Honda Civic (2001 - 2005)
10
Aug 27, 2010 11:32 PM
rjnyc
Feb 8, 2010 10:20 AM
dth0ng69
Oct 26, 2008 09:17 PM
da_33
Jul 10, 2007 03:21 PM
