Window + lock problem
When I arm my alarm it always locks/unlocks my drivers door but randomly will lock/unlock the other 3 doors. It used to work fine but now seems to be getting worse.
Today I put the drivers window down and now there is no power. None of the windows/locks work. Even when I try to put down the window using the REAR window switch it won't go down. But, the courtesy lights work.
I assumed it was the main plug in the drivers door that goes from the fender to the door, but why wouldnt the rear window switches work? I think it is partially the plug still.
Any ideas? I need to at least get the window up before tonight.
Was able to barely force the plug back together a bit more and everything works fine. I just need to find a better solution to keep the damn thing from coming apart.
I thought it was the plug but don't understand why the windows/lock won't work if the drivers door plug isn't connected. Oh well.
Juliano Rivera
Jun 11, 2019 10:55 AM
chris4x4
13
May 8, 2011 10:39 AM
