Where's the oil send line go to?
do you mean the source or the destination? destination is obviously the turbo and the source is probably on the oil pressure sender located tward the drivers side of the oil filter
You really have to jack the car up high and look to the drivers side a little lower than the oil filter which is covered by a rubber boot....you need to use a 24mm, correct me if I'm wrong, DEEP socket to remove that and depending on if you want to see a maintenance light or not....just put the oil feed in there and if you do care....you'll need a 1/8" NPT "T" fitting I'm sure but use your brain....a stud in the block, the oil sensor on the other end and the feed on top.
[Modified by Hellz99si, 3:25 AM 9/9/2002]
