Drag race brazil - Everton ET - Honda Civic SI #171
Old Mar 16, 2010 | 09:29 AM
Everton Et's Avatar
Default Drag race brazil - Everton ET - Honda Civic SI #171
Hello, first I apologize for my English.
My name is Everton Carvalho, known as Everton ET. I live in Brazil, I'm pilot Drag race.
I am currently the record holder of the category DT-B (limited to head 8v, 4 injectors and radial tires), with the time of ET 11.145 @ 137mp / h, weight 2546lbs. With a VW gol G4 with 568whp, turbo By bulls S366
The following videos my car
http://www.youtube.com/watch?v=VPfIt6MEd4E
http://www.youtube.com/watch?v=ax4vqFGssNg
Well, for the year 2010, I decided to innovate and build a Honda. Since 90% of cars drag race in Brazil are VW Gol.
Due to the rule book, I had to choose a Civic +06, because below 00 years I think were not manufactured in Brazil. And I will use q motor Serie K.
The next few items in the rule book.
Minimum weight 2270lbs
tires 24.5 x8 "
The car has all q be mounted
Not premit use of lexan.
Fuel released
Nitrous oxide prohibited
size turbine released
Spec
K24 - darton Sleeves
Head K20z3
The turbine that will want to use an S372.
Box tramissão'm seeing with the PPG.
Pistons WiSec
Rood Paute
Camshaft IPS
first pictures of my current car
preliminary layout
Photos of the project
Old Mar 16, 2010 | 10:06 AM
Everton Et's Avatar
Default Re: Drag race brazil - Everton ET - Honda Civic SI #171
desculpa pelas fotos grandes, achei que o forum diminuia automatico
Old Mar 16, 2010 | 10:25 AM
1992Si's Avatar
Welcome to the forum. Nice of you to seek us out for help.
You have come to the right place. Most of what your going to ask is covered here, but most of us are welling to help you. We understand the language problem.
Looks like you know what your doing, so you will get respect for that.
The one thing I do not understand is "The car has all q be mounted" ?
What is "Fuel released" ? Can you run high octane or must you run pump gas ?
Old Mar 16, 2010 | 10:32 AM
Everton Et's Avatar
Thanks .... Come on
About the fuel. is released, I can use gasoline, methanol, ethanol, nitromethane, either with or without fuel additives.
About the car has to be all mounted. May not have relief of pieces. All internal components has gotta be in the car, glass, seats, dashboard, door liner, etc..
I can not replace pieces of the bodywork, being lighter type of carbon fiber
Old Mar 16, 2010 | 10:36 AM
Everton Et's Avatar
I will use injection Fuel Tech FT400 to control the mixture of engine
http://www.fueltechusa.com/br/product/detail/215/ft400
Ja use Fuel Tech nomeu car, but the previous version.
For those not familiar with Fuel Tech, eh a Brazilian company, headquartered in Porto Alegre, Rio Grande do Sul, which was born of a TCC (work of completion)
What is now being published in the USA
Old Mar 16, 2010 | 10:53 AM
Vtec-G2teg's Avatar
music in 2nd vid = awesome!
Old Mar 16, 2010 | 11:02 AM
Everton Et's Avatar
Sorry, not very well intendi the term.
But if this praising the music, it was adopted as the theme of victory, when Ayrton Senna won some proof of formula one
Old Mar 16, 2010 | 12:35 PM
1992Si's Avatar
You'll want to watch some of the videos here and learn how to do a good burnout, (use 2nd or 3rd gear).
Also at the tree, if you see the green light, you loose. Learn how to leave on the last yellow. It takes practise, but you should not see the green, by the time it comes on your eye's should be looking forward.
Don't worry. The term "awesome" is a good thing.
Old Mar 16, 2010 | 01:08 PM
ewerton_cg's Avatar
congrats man! the car is sick!
revision the terms and words:
the brazilian "DT-A" class is like NSCRA True Street class, but just FWD's cars are permitted.
tires 24.5x8 Slicks
Full interior
All windows must be OEM glass. lexan are prohibited.
Any Fuel alowed (Nitromethane, E85, Ethanol, Alcohol, gasoline, race gas, vp, etc)
Any turbocharger size is permitted
Spec
Block K24 w/ Darton MID Sleeves
Head K20z3
Borgwarner S372 Turbo.
PPG Dog Box Transmission.
Wiseco Pistons
Pauter Rods
IPS KT2 camshafts
G/L Bro
Old Mar 16, 2010 | 01:29 PM
jtperf's Avatar
nice stuff bro! thank's for sharing your build with us, good luck!
Old Mar 16, 2010 | 01:43 PM
Everton Et's Avatar
hello
use 2 gear to burnout
On the start, these videos were my first race. In time improved.
hug
Old Mar 16, 2010 | 01:47 PM
Everton Et's Avatar
am here to learn.
Nobody better than you honda-tech to talk about these engines
Old Mar 16, 2010 | 01:48 PM
Everton Et's Avatar
I have a question about crankshaft.
I found it a little heavy. I wonder if they do some kind of relief in it. To let more light?
k24 crankshaft 99mm
Old Mar 16, 2010 | 02:29 PM
1992Si's Avatar
Not really up on K's, but most guy's just run the cranks as they come from Honda.
If you want to turn lots of RPM, PM guy's like miller or Tony1. They both run B's but I'm sure they know something.
We had our D16z6 lighten, but it's not really needed for what your doing.
As far as balancing the crank. When I asked the machine shop about that. They said the balancer manufacture told them if they ever had a question about the machine working correctly, just put any Honda crank on it, Honda cranks are near perfectly balanced, much better then any other crank out there.
Old Mar 16, 2010 | 03:32 PM
high_revs's Avatar
nice build man, cood luck with it, if you need any translating from portuguese to english or the other way around pm (personal message) me..
Old Apr 22, 2010 | 06:44 PM
Everton Et's Avatar
Giving an update ....
The VW Gol was sold.
Now begins the complete assembly of the civic.
Gradually I'll update.
Hug
Old Apr 22, 2010 | 06:47 PM
Everton Et's Avatar
I have a doubt about the connecting rod and piston.
The turbine to be used will be a GTX4202.
I am considering using Wiseco pistons and connecting rods adhere.
My doubts.
This configuration can handle the power generated by a GTX4202?
hug
Old Apr 23, 2010 | 01:49 AM
1992Si's Avatar
Glad to hear the VW is gone, now it's time to get serious.
The Wiseco's are a good choice.
For rods there are choices. Send a PM to guy's like Tony1, miller, or click on some of the links in the threads by the sponsors of this forum. Those are the guy's who's name appears in red. There are any number of great guy's/shop's here that will help you.
Can you use slicks on your car ? With the high HP you can make, your going to need them.
Here's a thread with a few of the guy's you'll want to talk to.
https://honda-tech.com/forums/moderated-threads-55/new-product-threads-forum-poll-inside-please-vote-2762157/
Thanks for coming back and updating us.
Old Apr 23, 2010 | 04:35 AM
Everton Et's Avatar
Thanks ...
On Slick tires. Yes I use Slick 24.5 "x8" 15 "or 13". perhaps for 2011 release 26 "
MP I have already sent to them. Thanks
Old Apr 23, 2010 | 05:39 AM
JO TECH's Avatar
Hey sir if you need any help with the car lmk I work with those cars everyday!!
My shop car runs 11.3 with stock engine!!
Welcome to H-T!!!!!
Old Apr 23, 2010 | 07:14 AM
1992Si's Avatar
There you go, there are a bunch of guy's on here that can do all kinds of things or help you out with advise and parts.
It's a great community to be part of.
Old Apr 27, 2010 | 03:44 PM
Everton Et's Avatar
To watching the rods manley
but I have a doubt
This value is set with four units or the unit value?
http://www.nolimitmotorsport.com/Mer...de=man-14405-4
Old Apr 27, 2010 | 04:15 PM
crispeed's Avatar
Looking good Everton.
Rodrigo Cohen from Fuel Tech was here at the shop last week. Seems like an interesting piece.
Good luck with your project.
Old Apr 27, 2010 | 04:19 PM
Adriano's Avatar
Esse kit de biela e completo (4). Qualquer pergunta me mande um mp. De onde vc e do brasil? Eu to indo pra ES essa semana e tbm to montando um civic turbo. Parabems no novo projecto.
Adriano
Old Apr 27, 2010 | 04:39 PM
Everton Et's Avatar
Adriano
Opa
Sou de porto alegre
