Spark Plug Change Intervals
Old Mar 16, 2010 | 09:19 AM
00si2's Avatar
Default Spark Plug Change Intervals
Is there anyway to tell that a spark plug needs replaced?
I've put about 10k miles on my car since finishing building it and having it tuned and have always swapped in a new set of plugs with every oil change at 2000 mile intervals. I've done this because that's what i was told by my tuner and also what i have read. I'm not complaining about the frequency or the cost, i was just curious if its actually necessary or if there's anyway to tell that they need changed besides watching the mileage? Is this common practice for the rest of you?
Old Mar 16, 2010 | 09:24 AM
turbo gsr2000's Avatar
Default Re: Spark Plug Change Intervals
when they start breaking up at high rpms <
Old Mar 16, 2010 | 12:04 PM
dpetro1's Avatar
i think every 2k miles is excessive. i do it every other oil change and even that might be a bit much. i guess it really depends on how you drive and your tune. my car runs pretty rich at cold idle so im sure the plugs dont like that too much.
Old Mar 16, 2010 | 12:06 PM
sleepencivic's Avatar
i do every other oil change as well and they allways look good...could probably go longer but ngk's are cheap!!
Old Mar 16, 2010 | 01:52 PM
welfarepc's Avatar
the copper core will start to lose conductivity around 5,000km.
if you pull the plug and some of the edges are rounded, time for new ones.
Old Mar 17, 2010 | 06:26 AM
00si2's Avatar
Thanks for the info. I think i might start doing them every other oil change. A lot of my miles are highway anyways.
karkess
Oct 15, 2009 02:28 PM
CRZ1
Apr 26, 2009 08:59 PM
ls19integra95
Mar 16, 2008 05:51 PM
Drew Peacock
Feb 7, 2003 05:28 PM
KF_S2000
Dec 3, 2001 07:42 PM
