honda del sol wiring?
Theres also a block off plate behind the e-brake, you could try putting the switch there. If you want to remove it you just have to replace the plate.
Or you could wire it to the aux light switch, but then you would have to have the aux lights on tho.
Usdm Del sol's do not have a fog light switch, they have aux. lights though if that's what you are talking about.
If it were me, I'd just wire it into the tail lights, and it will turn on with them. Unless you have the actual Honda rear fog switch.
Oh i thought i saw a switch for it. BUt yeah i originally wanted to wired it to teh tail light but i didnt know if it would be better to wire it to a switch? An i also have to wire the map lights on teh door panels and im not sure if to wire that to a switch??
dwnthehatch
17
Mar 12, 2010 02:34 PM
Zector
Oct 9, 2009 11:10 PM
