camber kit install
I have some questions, I got a 98 base prelude that I wanted to install camber kit. I tried to remove the upper ball joint and couldn't. How am i suppose to remove it? is there a special tool that I need?
alignment is still off, the tech adjusted the toe as far as he could already. That's what I been told, So i got myself a camber kit. I'll try to see if i can get the specs tomorrow.
You don't seem to know much about suspension alignment. Since you refuse to answer questions, no one can really help you.
However, there's no need to get your camber into "spec". The toe is the only thing that needs fixed. Provide more details and you'll get more help.
