someone please explain
Old Sep 8, 2002 | 04:26 PM
slowman's Avatar
I took way too long
Default someone please explain
i layed a little rubber patch in my driveway. no big thing. i was wondering if my car has LSD. i was driving around and i dumped the clutch once and my tires went up in smoke like a mother. i lost all steering. it felt like i was on ice. i dont think that Si's have LSD but why did i lose steering and stuff? here are the pics of the little streaks i made. you can see it(i know it sucks, its getting dark). the two marks. whats going on or why does it do this? or am i a dumbass and the si's have LSD?
Old Sep 8, 2002 | 04:39 PM
bfrank81's Avatar
Default Re: someone please explain (slowman EF)
I have a '91 Si and mine doesn not have LSD.
BUT! When I do a burn out my drivers side tire doesn't leave any mark but my passenger side goes up in smoke. Peg Leg!
LSD Coming soon......
Old Sep 8, 2002 | 04:42 PM
slowman's Avatar
I took way too long
Default Re: someone please explain (bfrank81)
so does this mean that i have LSD? was it some option you could pick from the factory?
Old Sep 8, 2002 | 05:16 PM
the DR.'s Avatar
just the front of the car up, leave the transmission in neutral, and spin one tire, if the other spins then you have LSD. (but i dont think that regular si's came with lsd)
Old Sep 8, 2002 | 05:19 PM
Jayseal22's Avatar
No, way did that car come with LSD. It's prob a matter of you dumping the clutch and the car not knowing which wheel to turn so it goes from one to the other real quick
Old Sep 8, 2002 | 05:41 PM
slowman's Avatar
I took way too long
Default Re: someone please explain (Jayseal22)
well if the driveline is not connected to both wheels, how would it go from one to the other real quick? and plus i have layed a serious muthafawking burnout for like 10 seconds and they both were spinnin like a motha. i had not steering at all. i will lay a bigger one tomorrow in my driveway just to make sure.
Old Sep 8, 2002 | 07:13 PM
rasta420's Avatar
i think its cuz in most front-wheel drive hondas, theres only one "power forward" and "power reverse" which means one wheel is receiving the actual torque, not both wheels. so if you dumped the clutch, that power forward wheel spun out and created the bigger tire mark on the ground, and finally the other side started rotating at the same speed as the power forward side.
not 100% on this, but pretty sure...
Old Sep 8, 2002 | 07:17 PM
xtrafastcivic's Avatar
Default Re: someone please explain (rasta420)
try doing the burn out for longer it will peg leg...
Old Sep 8, 2002 | 11:07 PM
Camoflauge89EF's Avatar
Default Re: someone please explain (XtraFastCRX)
Bro -
1990 Honda Civic Si's never came w/ factory LSD. That's just a "sometimes it happens" kinda thing.. nothings wrong w/ the car and no you don't have LSD. I can tell you who to talk to about getting LSD.. But i lay tracks longer, and chunkier than those. But i have a stock std (4spd) DX and my **** lays them thick...
Chad
Old Sep 9, 2002 | 03:27 AM
slowman's Avatar
I took way too long
Default Re: someone please explain (Camoflauge89EF)
yeah, i can lay one badass one too. thanks for the help guys. always wondered why it did that
89ED
Dec 26, 2013 12:21 PM
ek4ferrio
Sep 12, 2006 08:24 PM
crj_lll
Dec 16, 2003 01:24 PM
calitypeR
Jul 27, 2001 06:10 PM
