clutch? or tranny? problems...
Old Mar 15, 2010 | 07:26 AM
mrmoomoox's Avatar
Default clutch? or tranny? problems...
hey can run through gears but wont go anywhere speedo moves along w/ the gears and rpms but car won't move at all... i dont know if it was either the clutch went out.. or tranny went bad...
Old Mar 15, 2010 | 09:32 AM
DVDr's Avatar
Default Re: clutch? or tranny? problems...
What you are saying is , you give it gas and rpms goes up when your are in first gear but car does NOT move. correct ?
Sounds like the transmission is not engaging with the motor.
So sounds like clutch.Pressure plate or hydraulic problems.
Start by checking your fluids, if they are full, get a buddy to see if when you are pressing the clutch pedal he can visually see something happening by the slave cylender.
Or might be as simple as your clutch is worn/broken.
Old Mar 15, 2010 | 09:35 AM
Ruben19's Avatar
sounds like u need a new clutch
Old Mar 15, 2010 | 09:40 AM
delsolproblems's Avatar
Watch the clutch slave cylinder while someone presses the clutch and see how much it moves, if at all.
Old Mar 15, 2010 | 11:50 AM
apexi_rsx's Avatar
if it aint goin no where how can u read the speedo and the rpms? was the clutch slipping previously at high rpm?
Old Mar 15, 2010 | 12:09 PM
Well the tach would still work if the car isn't moving, but apexi has a point about the speedo. Your speedometer moves when the car doesn't?
Old Mar 15, 2010 | 12:41 PM
pityocamptes's Avatar
If the speedo is working I would assume your tranny took a dump. Sounds like the output craped out. because for the speedo to work (which runs of the tranny gearing) your motor would have to be turning the input gears. Unless of course you snapped the half shafts or stripped the output splines...
Old Mar 15, 2010 | 11:14 PM
mrmoomoox's Avatar
thx yeh slave is engaging and fluid is fine i dont think theres a hydrolic prob.
mrmoomoox's Avatar
no slip before
Old Mar 15, 2010 | 11:15 PM
mrmoomoox's Avatar
thanks alot i'll give that a look and we'll see
Old Apr 5, 2010 | 12:14 AM
mrmoomoox's Avatar
sooo... it had seem that my axle popped out ahhahaha and that explains alot.... and popped it back in and its fine now woohoo ez fix
Old Apr 5, 2010 | 06:05 AM
Jimster480's Avatar
If your Speedo is moving but your car isnt, then your diff or output shaft in the tranny went. Thats all there is to it.,
Edit: I just read that the OP fixed their problem. So you were saying that only 1 Axle was out?
mfisher1987
Transmission & Drivetrain
Feb 8, 2015 05:58 PM
kpjo4
13
Jan 6, 2010 12:47 PM
rriicckk787
May 10, 2005 05:13 PM
CimorelliCRX
Dec 15, 2002 04:02 AM
