No speedo, vtec problem
Old Mar 14, 2010 | 11:28 PM
TristanW10's Avatar
Icon2 No speedo, vtec problem
I done a b16 swap and vtec does not work, it is wired up but the cel, throws a vtec code. The speedo works only part of the time, could this be my problem or not?, thanks
Old Mar 15, 2010 | 01:31 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: No speedo, vtec problem
check the wiring for your speedo sensor on the transmission and make sure its not loose or not plugged in.
Old Mar 15, 2010 | 07:02 AM
TristanW10's Avatar
i know its plugged in, the speedo didnt work right on the d series either.
Old Mar 15, 2010 | 01:13 PM
RichSC's Avatar
Yes, the speedometer must be working for VTEC to work. What codes are you throwing?
Old Mar 15, 2010 | 01:58 PM
TristanW10's Avatar
only code is the vtec code, does the oil pressure sensor on the vtec selonoid have to be hooked up?
Old Mar 15, 2010 | 02:23 PM
AllJdmR's Avatar
if ur vtec solenoid is not connected ur vtec wont work..if thats wat u mean...
Old Mar 15, 2010 | 02:45 PM
RichSC's Avatar
Is it 22 for the VTEC pressure sensor, or 21 for the actual solenoid? And yes that pressure sensor has to be connected for VTEC to work.
Old Mar 15, 2010 | 03:33 PM
TristanW10's Avatar
ok i read another thread and i understand how the pressure switch bypass works now, i think the problem with my vtec is that my speedo doesnt work, anyone near vincennes, indiana have an extra one?, lol.
HondacivDX
Feb 19, 2012 03:25 AM
cleanazcoupe
Jun 30, 2009 10:28 AM
cesareDOHC
Mar 6, 2004 02:53 PM
jonas
Mar 15, 2003 03:09 PM
