Ignition switch problems?? 91 CRX SI.
Old Mar 14, 2010 | 08:40 PM
puertoricanboy90's Avatar
Default Ignition switch problems?? 91 CRX SI.
So, I just bought a 91 Rex, with a DOHC ZC motor in it and i wasn't able to keep it running after getting it home because of a problem with my ignition cylinder/switch. If i hold the key in a position half-way before engaging the starter and the "on" position, the car will stay running. If i let go and it returns to the on position (like it should) then i lose all accessory power [and the fuel pump doesn't prime] except for my radio. Now, what i would like to know is whether my issue is related to a faulty ignition key cylinder or if my ignition switch/wiring could be culprit. Any suggestions would be great.
Old Mar 14, 2010 | 08:50 PM
2point2's Avatar
Default Re: Ignition switch problems?? 91 CRX SI.
It's not uncommon to have an issue with the 'switch'.
Old Mar 14, 2010 | 08:54 PM
Why the hell you put quotations around the switch... you're confusing me, lol? You didn't answer my question though... would my symptoms be SPECIFICALLY indicative of a faulty switch or locking cylinder?
Old Mar 14, 2010 | 09:19 PM
D16SiHatch's Avatar
haha, good point. definitely stange to quote "switch" lol, but whatev
anywho, yes your problem points to a failing ignition switch. test it out though if you want to be sure
http://mycomputerninja.com/~jon/IgnitionSwitch.html
Old Mar 16, 2010 | 06:41 PM
Thank you very much for the reply. I was fiddling with it last night and could get the motor to remain running a few times. The part will be in tomorrow.
Old Mar 16, 2010 | 11:25 PM
BadassEFdriver's Avatar
have you tryed just swaping out the ignition cylinder? i know its screwed on by bolts that dont have any patern (screwdriver, phillips, socket, etc.) but I mananged to get mine off by using a air-powered saw to cut grooves into the screw so i can get em off with a flathead screwdriver. or you can just use any type of saw, Hope this helps if you ever attempt to swap it for another one
Old Mar 17, 2010 | 03:04 PM
88whitehatchidaho's Avatar
its not the key tumbler, its the switch on the back of the lock assembly, two screws hold it on. its easy to do i had the same problem in my car
fazalabbas
Jan 5, 2019 10:36 PM
bradbrisbin
Oct 30, 2012 08:07 PM
b00sted4dr
Jul 31, 2006 05:00 PM
benmyfriend
Dec 4, 2005 09:54 PM
