Forgiving-ish clutch for Turbo Application
Old Mar 14, 2010 | 08:02 PM
Wagonist's Avatar
Default Forgiving-ish clutch for Turbo Application
I have a boosted F22B1 (bottom end built) in an Accord wagon that requires a new clutch. I had the clutchmasters FX-400 6 puck sprung, but apparently I suck ***** with something so aggressive. I found engagement very harsh which resulted in me riding her bad while I was getting used to it as she's gone dead in about 700miles.
I'm looking for a clutch that can handle 300-350wtq but will still be easily streetable.
Does anyone have any experience with the Clutch Masters FX-300, the Competition Clutch Stage 3 - Street-Strip Series 2300 or the ACT XTreme?
Thanks.
Old Mar 14, 2010 | 09:00 PM
runsfromdacops's Avatar
Default Re: Forgiving-ish clutch for Turbo Application
cc twin disc. i just started driveing mine on the street and love it. my gf can drive the car with out a problom, its a much beter clutch the the act unsprung max extrem 6 puck i had and it can handle alot more power.
Old Mar 15, 2010 | 08:04 AM
Muckman's Avatar
Moderator in Chief
The CM Stg 4 that you have is on the nicer side of the scale compared to the ACT Xtreme. The CM Stg3 could be a factory clutch IMO.
Old Mar 15, 2010 | 08:15 AM
narfdanarf's Avatar
CM stage 3 started slipping on me at about 300 ft lbs, then I switched to ACT sprung 4 puck, and I had pretty good luck with that, although it was a little harder to drive. I have a CC twin now though and will never go back.
Old Mar 15, 2010 | 12:22 PM
Wagonist's Avatar
After reading some reviews, I'm looking at the Competition Clutch Stage 4 with a 6 puck sprung.
Old Mar 15, 2010 | 12:30 PM
boostedEF91's Avatar
i have the comp clutch stage5 with 4puck sprung and the heavier Rated Pressure plate. and i love it. the pedal still feels stock. and its not bad driving with at all.
Old Mar 15, 2010 | 12:32 PM
Turbo-LS's Avatar
even if your riding the clutch alot i seriously doubt you wore down a 6 puck disc in 700 miles. Th fx-400 isnt even that harsh of engagement. its about comparable to the stage 4 comp clutch. there basically both the same setup but the comp has a little softer pedal. sounds to me like oil on the clutch face. see what it looks like when you take it apart i gues but 700 miles idk bout that.
ive been running an ebay stage f1 racing clutch for 22k miles and its still holding, so a clutchmasters done in 700 miles even with a terrible driver just doesnt add up. are you running a god crankcase ventilation system?
Old Mar 15, 2010 | 12:59 PM
Wagonist's Avatar
Hmmm, my return line is leaking a bit at the oil pan (garage botched it). Maybe that is the culprit....yet another thing on my list of required corrections.
s2k_8582
Honda S2000
Jul 20, 2011 12:09 AM
91integraLSVTEC
Sep 13, 2003 12:43 AM
Nextelbuddy
18
Jul 8, 2003 07:46 AM
SubieDude
Oct 22, 2002 07:23 PM
