Civic running Cold!!
Old Mar 14, 2010 | 07:48 PM
JAPANMUSCLE's Avatar
Default Civic running Cold!!
My civic only sees normal operating temp when at idle when i start to move the temp goes down half way in seconds - i just replaced the radiator termostat engine temp sensor and coolant annndd water pump when it does reach normal temp on gauge the fan kicks on this is drivng me crazy any help is greatly appreciated
2000 civic si
Old Mar 14, 2010 | 09:15 PM
92B20's Avatar
Default Re: Civic running Cold!!
bump
mine does the same after i propped up my hood.
Old Mar 14, 2010 | 11:48 PM
Linked's Avatar
@ idle, fans are suppose to kick in, not when driving though
Old Mar 14, 2010 | 11:49 PM
jasoncanseeoh's Avatar
in for the solution
Old Mar 15, 2010 | 12:18 AM
Mr. Em1's Avatar
hmm that seems like a weird issues, its seems like you have replaced almost every component that would effect the cooling system. If you can't figure it out maybe run the fan on a switch so you can turn it on and off when you like..?
Old Mar 15, 2010 | 01:44 AM
Acuronda_SloTeg's Avatar
highly common bizzness here, my homeboy is an acura mechanic and he has two cars that do it. he tried going to a honda oem thermostat and his acted normal again, but the other one didnt so i guess its like shootin the breeze in hopes to get it right
Old Mar 15, 2010 | 03:54 AM
i've seen people with cardboard sticking from the tops of there radiators is that to reduce air flow to keep the car at normal operating temp while driving?
Old Mar 15, 2010 | 07:12 AM
Mishimoto's Avatar
^^ That is most likely the reason they are doing that, however, I do not recommend it. I would get a different temperature T-Stat instead.
Old Mar 15, 2010 | 07:19 AM
At lunch i am going to hook up the HDS and see what the coolant reads at - I will keep everyone posted because every other thread i have found no one posts any resuslts to know how the car was repaired
Old Mar 15, 2010 | 10:22 AM
letam06's Avatar
I also have a similar problem. Well I have a cx racing dual core radiator with new piping and a brand new oem thermostat. I have my fan wired on a custom on/off switch. My temps never get higher than a 1/3 of the way up. Well unless I leave the fan off and let idle fora good half hour. But than as soon as I drive it it goes right back down. Should I buy an aftermarket thermostat that opens at a hotter temp. I'm worried about damaging something.
Old Mar 15, 2010 | 11:35 AM
DVDr's Avatar
What is the temperature outside ?
Try disconnecting the fans and see if your coolant temp goes down with operation.
( do you have an aftermarket coolant gauge to diagnose exactly the temperature ? ) .
and you replaced the thermostat with an OEM honda correct ? do you know what temp rating you have ( or partnumber you purchased )
Old Mar 15, 2010 | 11:51 AM
sleespeed's Avatar
did you use all oe honda parts?
Old Mar 15, 2010 | 12:42 PM
Str8EJ's Avatar
Is the system properly bled?
Old Mar 15, 2010 | 12:51 PM
Tomcat's Avatar
You might be losing some cooling system pressure due to a small radiator leak. Even a small drop in cooling system pressure will cause the car to take much longer to warm up; if it's cool outside and you are driving on the freeway.
Old Mar 15, 2010 | 08:32 PM
letam06's Avatar
Cx Racing Dual Core Radiator is brand new. Had it for maybe 2 months before I took my civic off the road for winter. Tubing is all new as well. Cant remember the brand but its blue. haha. No leaks of antifreeze at all coming from anywhere. No white smoke or smoke of any sort so I know none is being burned either. All the gaskets on the head were replaced with about 2 months of DD on them with Falpro Gaskets. The system is also properly bled. Thermostat is OEM Honda and its for the 94 DelSol or 99 Civic Si since I have a B16a. I believe it opens at 160. Was tested in hot water before I installed. Also replaced the water-pump from a 94 DelSol VTEC. I have a switch on the interior that turns the fan on and off. So I know its not an issue that deals with the fan/wiring. I can leave it off driving down the road at any speed and temp. is still at 1/3. If I let it idle for a like 30+ minutes than it will start to overheat and the fan must be turned on. I do not have an aftermarket temperature gauge, hopefully will within the next few months. The outside temp. is anywhere from 70 degrees to 90 degrees. I Live in Michigan and take my Civic off the road for the winter and garage it.
Old Mar 15, 2010 | 08:49 PM
FRESH.EJ1's Avatar
My civic also has this weird cool running state. I live in florida so i believe it is even more weird. I turned on the A/C and had like a somewhat hard run and the temp barely raised. I had weird idle/ a little white smoke, but i think it was due to running 6 month+ old gas (it sat for a while). Car has no leaks, and i checked the radiator inlet and outlet hoses, both were pretty hot when i grabbed them. It also stays at 1/3 temp.
Old Oct 22, 2011 | 05:06 AM
lhommedangereux's Avatar
mine does this too. the thermostat i bought from autozone was rated 170 degrees (according to them thats the supposed operating temp for a 99 civic si) however i was on a racing site looking at thermostats and one said the recommended operating temperature is 190 degrees. so i went on ebay and found a 190 degree thermostat for 9 bucks. i realize this is an old post but maybe this will help someone else with this issue who finds this thread. good luck!
Jamie Steadman
Aug 14, 2015 12:07 PM
Steeve_Civic
Sep 24, 2013 05:04 AM
nicknack25
Feb 23, 2012 07:21 AM
jds62f
36
Jul 9, 2011 07:48 AM
Mr. Stiles
May 31, 2006 08:46 AM
