stock b18b1 rev
Old Mar 14, 2010 | 06:19 PM
vteck1ck's Avatar
Default stock b18b1 rev
I want to know how high can you rev a stock b18b1 with a chipped ecu without blowing your motor?
Old Mar 14, 2010 | 06:38 PM
DVDr's Avatar
Default Re: stock b18b1 rev
Depends on condition that its in.
But 7000 rpm probably the highest I would go ( well highets I went when I had a b18b ).
It really doesnt make more power past that ,so no point going higher .
( in case you have cams, and springs ) then probably will make more power up top, add some arp rob bolts and probably can rev it to your power peak
Old Mar 14, 2010 | 07:26 PM
vteck1ck's Avatar
I'm going Ls Vtec so I wanted to know the limit of revving a Ls
Old Mar 14, 2010 | 08:49 PM
Dirty_SL8's Avatar
Untouched b18b= about 7500 max.
lsVtec b18b= about 8200.
The weak point is the head and rod bolts on a ls. Swap the head with a vtec head and put rod bolts in it and you have an engine that will go to 9000 (with valve train that will handle it). Remeber not to get drawn into the thrill of rpm.If you aren't still making power..... why hold it out.
Old Mar 14, 2010 | 09:06 PM
dapek's Avatar
Whoever is chipping your' ecu should be able to set a rev limiter for you at a safe point for a internally stock ls-vtec your doing. If you want to rev anywhere past the stock limiter then you should think about building the engine. It would be pointless revving so high seeing as how you aren't getting any power that high as someone already said.
Old Mar 15, 2010 | 06:04 AM
Matt93eg's Avatar
Two great responses IMO. There's no point in revving a stock LS past redline because it doesn't make power up there with stock Cams. Some people I know with a stock D16Z6 go all the way to the 7200RPM Redline or a bit beyond and its just pointless. A stock D16Z6 signs off right around 6800. That's where I always shifted my D16Z6 because what was the point of hanging it out another 400-600RPMs when it wasn't making any power and fell on its face.
Sk8ermane
Feb 17, 2008 09:12 AM
warrenh32
Oct 3, 2007 01:56 AM
Greenery18
15
Feb 21, 2007 07:11 PM
DARKTEG_
Oct 25, 2006 08:02 AM
UltRaH22
May 24, 2003 09:08 AM
