2.0L ITR swap 246hp/155tq
Old Mar 14, 2010 | 01:47 PM
darrinbrewer's Avatar
Default 2.0L ITR swap 246hp/155tq
car's setup
2.0L sleeve'd ITR block, eagle rods, around 11.5:1 looking srp pistons (dont know for sure on piston CR)
ITR head, stock port, stock intake mani, stock throttle body.
Password JDM carbon 'whale' intake
370 precision injectors
Skunk2 stage 2 cams, full sk2 valvetrain
Profab 4-2-1 Big tube header(2.5" outlet and test pipe)
i think a apexi ws2 exhaust, (dont remember)
peak hp was 214, tq was136
at peak power 8600 rpm,
AFR is 13.2:1
injector duty cycle is 76% at 55psi with walbro 255hp pump
This is on a mustang dyno, if you google mustang dyno vs dynojet, and read threads from all type of forums (mustang, ls1tech, and others)
you'll see a mustang reads approx 15% lower,
thus if you add 15%
this car has approx 246hp, and 155 TQ Tuned by me on crome Pro
SORRY ABOUT THE YELLOW TEXT..peak hp was 214, tq was136
the mustang dyno exported to a TXT file, so i pasted into excel and made the graph above from that data.
the dyno operator had a program on the dyno that populated all the car spec fields, wieght, etc.. and it had 92 civic, 1.5 (which this car was a dx) and i think the weight was 2360 or so if i remember correctly? so the numbers arent 'enhanced' or anything.
Old Mar 14, 2010 | 04:17 PM
flesh199's Avatar
Default Re: 2.0L ITR swap 246hp/155tq
all of this power tru a 60mm exhaust?
thums up to you dude nice job!
Old Mar 14, 2010 | 06:36 PM
Teamdiesel's Avatar
I am sorry but I just don't see you making anyway near 246WHP on that setup. You need to go to a dynojet and get some real numbers instead of some inferred figures.
Old Mar 14, 2010 | 06:40 PM
rev-speed's Avatar
big numbers 4 such a mild built......
take it to the track mph don t lie
Old Mar 14, 2010 | 07:33 PM
UncleD's Avatar
*waves bullshit flag*
Old Mar 14, 2010 | 07:43 PM
Fresh'86's Avatar
Yeah, I don't see that setup being anywhere close. Never add %, just take it to a dynojet and see for yourself.
Old Mar 14, 2010 | 07:48 PM
the car was "tested" on a aem previously, just a 30 minute base tune, on a different dyno
a dyno dynamics, and it did 220hp there, so 214 on a mustang after a day of tuning doesnt sound far fetched. does it?
214hp and 136tq on a mustang dyno, figure up the 'correct' numbers however you wish.
it's usually about 15%
i doubt the car will ever get tracked, its a every day car for the guy.
the torque in 5th gear on the highway feel's crazy.
here's the txt file printed out from the dyno:
----------- Test Dataset #1 -----------
--- As Tested At ---
Image One Motorsports
3333 Hwy 11 W
Blountville, TN 37617
423-361-1065
Date/Time Tested: 2010-03-13 12:37:31
--- Customer ---
Name : Black Civic Josh Doyle
Address :
Phone :
--- Vehicle ---
VIN :
License Plate : 1234
Yr/Make/Model : 1992 / Honda / Civic
--- Test Data ---
Filter Mode : FIR
Filter Level: 15
Engine Speed, Eng Torque, Eng Power , AFR
RPM, Ft-Lbs, HP, Ratio
Run #, 1, 1, 1
2107, 25, 10, 12.1
2207, 62, 26, 12.2
2307, 96, 42, 12.7
2407, 105, 48, 13.4
2507, 109, 51, 13.5
2607, 113, 55, 13.5
2707, 114, 58, 13.5
2807, 116, 61, 13.5
2907, 119, 65, 13.6
3007, 117, 66, 13.4
3107, 116, 68, 13.3
3207, 114, 69, 13.3
3307, 115, 72, 13.2
3407, 116, 74, 13.2
3507, 117, 77, 13.2
3607, 119, 81, 13.3
3707, 118, 83, 13.2
3807, 119, 85, 13.3
3907, 120, 88, 13.3
4007, 120, 91, 13.3
4107, 121, 94, 13.3
4207, 121, 96, 13.2
4307, 121, 98, 13.1
4407, 121, 100, 12.9
4507, 121, 103, 12.9
4607, 122, 106, 12.9
4707, 121, 108, 12.8
4807, 122, 111, 12.8
4907, 122, 113, 12.8
5007, 123, 116, 12.9
5107, 124, 120, 13.0
5207, 126, 124, 13.0
5307, 127, 128, 13.0
5407, 126, 129, 13.1
5507, 125, 130, 13.0
5607, 125, 132, 13.1
5707, 126, 136, 13.0
5807, 127, 140, 13.1
5907, 128, 144, 13.3
6007, 127, 145, 13.4
6107, 126, 146, 13.5
6207, 124, 146, 13.2
6307, 124, 149, 12.7
6407, 124, 150, 12.4
6507, 122, 150, 12.2
6607, 121, 152, 12.0
6707, 121, 154, 11.9
6807, 122, 158, 12.0
6907, 124, 163, 12.3
7007, 127, 168, 12.5
7107, 128, 172, 12.7
7207, 129, 176, 12.7
7307, 130, 180, 12.8
7407, 133, 186, 12.9
7507, 134, 191, 13.0
7607, 135, 195, 12.9
7707, 135, 198, 13.1
7807, 136, 201, 13.4
7907, 136, 204, 13.3
8007, 136, 207, 13.2
8107, 136, 209, 13.1
8207, 134, 209, 13.1
8307, 133, 210, 13.2
8407, 133, 212, 13.2
8507, 132, 213, 13.3
8607, 131, 214, 13.2
darrin.
Old Mar 14, 2010 | 09:29 PM
92integraVTECgsr's Avatar
I agree.. Take to a Dynojet and get a real print out from the screen. Those are some huge numbers.
Old Mar 14, 2010 | 09:30 PM
Either way.. forget about numbers, I'm sure the car is a blast to drive. But real numbers would be nice.
Old Mar 14, 2010 | 09:56 PM
Justin Jones's Avatar
there's no way that setup would make 246whp
Old Mar 15, 2010 | 03:03 AM
egb18c5's Avatar
i concur
Old Mar 15, 2010 | 04:10 AM
OH_1fstgsr's Avatar
I am running 370 injectors right now. What is the duty cycle on the injectors at that horsepower level?
I am at 70% duty cycle with stock fuel pressure and am at 200/140 on a dynojet.
I would think those injectors should nearly be maxed out.
Old Mar 15, 2010 | 07:23 AM
Meister vtec's Avatar
I would go and get it tuned on a dynojet and come back saying in your face if I were you,just kidding.
but yeah I too think the number you came up with (15% difference) is a little overkill,I had figured that it was more so 6-8% by looking at others experiences,atleast with hondas.I think that would put you at around 230whp which is also great dude so why sweat,
good job,enjoy! stop the hp guessing games and kick some VW,V8 *** already:9
Old Mar 15, 2010 | 07:26 AM
Teamdiesel's Avatar
I was saying the same thing! I use RC 550cc injectors and make 249whp at 68% duty cycle.
Old Mar 15, 2010 | 07:42 AM
i'll chech the duty cycle when i get home. Fuel Pressure was at 55psi and using a walbro 255hp pump.
intake temps were between 102 and 130 the whole day
Old Mar 15, 2010 | 02:16 PM
AFR is 13.2:1
we were in the high 80%s till i noticed someone cranked the FPR DOWN to below stock levels
so i was able to turn it up and lower the duty cycle back down
EFhothatch15
Jul 8, 2009 11:07 PM
RNbuilt
Feb 17, 2008 11:45 AM
nokturnal_munkeeboy
40
Jun 26, 2007 04:43 PM
Aklude_h22a
13
Mar 9, 2006 05:44 AM
b19coupe
Oct 17, 2003 04:50 PM
