how do I test my injectors
I have a 1995 d16z6 with a p28 ecu in a 91 hatch, every thing is wired. I got the car to start for a second, now im not getting injector pulse. I put a screw driver from the injector to my ear and didnt hear anything. The fuel pump is working and i can hear fuel going through the fuel rail. What should I check?
i have checked the wiring it should be wright and it doesnt have the resister box i took that off and used the injectors from the d16 could it be the injector relay and if so how do i test it and allso the injector ground is hooked to the motor is that ok
how do you adjust the tps on this engine or how do you test it it has a bad idle and when you drive it it surges til like 2000 rpm then is ok but has no power
n2oef
Jan 21, 2005 12:54 AM
