Well it finally happened........KABOOM!!!!
Old Sep 8, 2002 | 02:45 PM
CrX1988Zc's Avatar
Default Well it finally happened........KABOOM!!!!
Yep, friday night i was racing a 3000GT VR4, pulled ahead of him in 3rd gear and bounced rev limiter and BOOM shot oil all over his car and whoever was behind me, pulled over and found a hole in my block in cylinder #3.
#3 already had low compression numbers, so i knew it would happen, just not this soon.
that was 11 psi on a zc w/cartech fmu and inline pump untuned.
i will be pulling the motor apart soon to find out all the damage.
R.I.P ZC 9/6/02
and if anyone has a spare zc block or zc motor, or even a sohc in the MD/VA/PA/DC/DE area. IM me or reply here.
Old Sep 8, 2002 | 02:47 PM
bullz's Avatar
Default Re: Well it finally happened........KABOOM!!!! (CrX1988Zc)
Damm your call pulled hard then, good luck on your next ZC.
Old Sep 8, 2002 | 03:24 PM
ski_rebel_3's Avatar
Sorry to hear that man. Good luck on your new project!
Old Sep 8, 2002 | 03:50 PM
Foozball26's Avatar
Default Re: Well it finally happened........KABOOM!!!! (ski_rebel_3)
were yo on a stock bottem end? or was it built
Old Sep 8, 2002 | 04:12 PM
integra-modder's Avatar
Default Re: Well it finally happened........KABOOM!!!! (foozball-26)
i hope it wasnt built... not to blow at 11 pounds...
Old Sep 8, 2002 | 04:16 PM
CrX1988Zc's Avatar
Default Re: Well it finally happened........KABOOM!!!! (integra-modder)
nope, motor was completely stock
Old Sep 8, 2002 | 05:09 PM
civbeater90's Avatar
how much you lookinf to spend on another zc?
Old Sep 8, 2002 | 05:12 PM
CrX1988Zc's Avatar
Default Re: Well it finally happened........KABOOM!!!! (civbeater90)
$300 or less
i might just need a block, havent looked at the head yet
Old Sep 8, 2002 | 06:09 PM
CzanSOHC's Avatar
man that sucks...but you asked for it ...good kill though..good luck
Old Sep 8, 2002 | 06:17 PM
pelotudo's Avatar
Ouch.. I'm paranoid now runnin my 7psi. Maybe I'll adjust that WG down to 6 or so for a while until the bad Karma clears the air.
On another note; whelp, looks like I'm once again the fastest 4gZCTurbo now
Sorry to hear about it though.
jB
Old Sep 8, 2002 | 06:26 PM
Danger's Avatar
Default Re: Well it finally happened........KABOOM!!!! (PeloTudo AKA Gringo)
damn , always sad to blow a motor . good luck with the next zc !
Old Sep 8, 2002 | 07:53 PM
*Boostwerks*'s Avatar
jB
Hahahahah....no your not.
Old Sep 8, 2002 | 11:22 PM
ion_four's Avatar
Default Re: Well it finally happened........KABOOM!!!! (Bryson)
just curious...did it blow because the stock rev-limiter cuts the fuel and not the ignition and thus detonated?
Old Sep 9, 2002 | 12:03 AM
rjardy's Avatar
jB
are you sure that hes not faster then your 14 second 1/4 mile ?
Rob
Old Sep 9, 2002 | 01:37 AM
hondaswaper's Avatar
Default Re: Well it finally happened........KABOOM!!!! (rjardy)
zc rods can only handle like 220 @ the ground...........
Old Sep 9, 2002 | 03:58 AM
Charlie Moua's Avatar
noooo i'm not that sorry for you... why because you should of had it tuned and you knew you has bad comp#. I did you have fun wasteing your money. Not trying to be a gerk(even though i sound like one right now) Just have fun on your next ZC ot whatever and learn from your mistakes.
Old Sep 9, 2002 | 04:01 AM
pelotudo's Avatar
Awwww crap, forgot about u
Looks like Brysons' car is going to have some extra "mods" by the end of the day.
jB
Old Sep 9, 2002 | 06:24 AM
AcuraFreak's Avatar
Ahhh the lessons we learn...Good luck to ya man !
Old Sep 9, 2002 | 06:35 AM
FOrSfEd's Avatar
Default Re: Well it finally happened........KABOOM!!!! (AcuraFreak)
Damn dude that sux, time to build and boost.
Lee
Old Sep 9, 2002 | 06:53 AM
SJP0tato's Avatar
What size injectors with what ratio of FMU? I'm guessing stock injectors with a 12:1? In that case, at 11 psi you would theoretically see 11(12) + 38 = 170 psi at the injectors. There's no way the injectors could take that much (if the fuel pump could even try to hold that much pressure). I'd say find a better method of fuel delivery for your next motor, or it'll die the same way as this one.
Good luck,
Ryan P.
Old Sep 9, 2002 | 09:14 AM
Well I wasn't even implying that "I" was the fastest....
I bet there are at LEAST 20 people with ZC turbo's that are running way faster then both of us.
AbaZ has got to be the fastest currently.
Old Sep 9, 2002 | 10:08 AM
HybridHatchC1's Avatar
i can get you a d15b7 the 8valve engine and tranny and stuff? want it i am only like a hr from pasadena?
Old Sep 9, 2002 | 01:36 PM
CrX1988Zc's Avatar
Default Re: Well it finally happened........KABOOM!!!! (Civ-JDM)
Civ-JDM, yea, all i need is the motor, how much you want for it and where are you at?
and i wasnt using a shitty Vortech 12:1 FMU either, i was using an adjustable cartech FMU/Regulator, you can adjust how much fuel goes in static and under boost. oh yea and stock injectors with an msd inline pump.
yea, i learn from my mistakes, but i didnt really care about this motor too much kinda hope it would last at least until october or november, but oh well **** happens.
LurkerS8
Jun 15, 2011 12:32 AM
Lowdreams
31
Jan 4, 2007 09:17 PM
sohcvtec91hatch
11
May 4, 2006 05:24 PM
themex77
Jan 31, 2005 05:20 PM
pirocrxracer
Sep 30, 2003 05:38 PM
