what wiring and ecu do i use on my h22a in my 98 acura cl??????
i have a 98 acura cl and just swapped in a obd1 h22a motor with auto trans it had a f23 sohc vtec motor in it and not sure what distributor,wiring harness or what ecu i should use and the obd1 h22a dont have a crank sensor on it so can i put in a crank sensor or i need to use obd1 ecu ? do i have to swap out the in car harness also ?? thanks for any info
blacklude98
Aug 9, 2009 03:16 PM
